RV.Net Open Roads Forum: Can I and Should I tow a Park Model one time short distance?
Search only in Towing
Open Roads Forum  >  Towing
 > Can I and Should I tow a Park Model one time short distance?
bankcardrep1
Asheville, nc
Posted: 07/21/12 08:42pm Link  |  Print  |  Notify Moderator
I have a 06 Chevy Duramax, 2500.
Someone asked me to tow their park model to a permanent spot.
Maybe 75 miles of intersate.
40' Trailer.
I am accustomed to pulling 28' TT and have had experince with longer.
Not concerned about my skilss as much as the truck ability to tow safely and not damage truck.
carringb
Corvallis, OR
Posted: 07/21/12 08:52pm Link  |  Print  |  Notify Moderator
Only things I would be worried about is:
1) capacity of your hitch receiver
2) condition of the trailer's tires
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
bailer6334
Prescott, AZ
Posted: 07/21/12 08:53pm Link  |  Print  |  Notify Moderator
At a minimum you need to know the max conventional trailing capacity for your truck. Then you need to know the tongue weight for the Park Model. Then you'll know if you can tow it.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
eric james
Sioux Falls, SD
Posted: 07/21/12 09:06pm Link  |  Print  |  Notify Moderator
I agree. Running down the road at 55 won't be bad for 75 as long as the receiver and trailer tires are intact. Use your wd hitch and a calm wind day.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
chevor
US/Canada
Posted: 07/21/12 09:14pm Link  |  Print  |  Notify Moderator
I have pulled new ones out of the factory to dealer lots. Trailers of that size need to be pulled slow with that size truck. I dont drive over 55 MPH with a trailer over 40' long and 12' tall. I wouldnt attempt tp pull an old used Park trailer with my truck.
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 497,500 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
Gale Hawkins
Murray, KY
If it is loaded (someone living in it for a while) the weight may be an issue.
Know a mobile home mover that has to get people to move out like a ton of books, etc so it does not come apart down the road.
Bob Shaw
Newnan Ga
Posted: 07/21/12 09:24pm Link  |  Print  |  Notify Moderator
I have a park model, and in my opinion, you don't have enough truck, 75 miles is not a short distance, and (at least in Florida) you need a special permit to tow a 12' wide trailer. I also tow a 40' 5th wheel, and I can tell you, my park model is much heavier than my 5'er. I would respectfully decline. Look, they have companies that move these things and it can't be that expensive, as compared to what it would cost if something goes wrong.
Joy
Henderson KY 42420
Posted: 07/21/12 09:32pm Link  |  Print  |  Notify Moderator
Considering the liability you would be incurring, I would pass. They need a commercial mover to do this.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
RoadLife
New Mexico
Posted: 07/21/12 11:46pm Link  |  Print  |  Notify Moderator
Yep, the one thing I would worry about is liability. If something happened while you are towing it, you are responsible. Your would need insurance to cover it. Since it's for a friend, your current insurance might not cover it...Something to think about.
ROADLIFE
RoadLife USA 2013 Blog
2003 40' Allegro BUS - 2 slides
2013 Ford F150 XLT 4X4 OffRoad 2009 RAV4
Shasta - Australian Shepherd; Boomer - Brittany
Cummins12V98
on the road
Posted: 07/22/12 12:33am Link  |  Print  |  Notify Moderator
No
Tell them to not be such a tight azz and pay someone to haul it.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
