RV.Net Open Roads Forum: PEX & Sharkbite
the bear II
Torrance CA.
Posted: 07/24/12 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I had my first experience this past weekend using PEX tubing and Sharkbite connector for a plumbing project in the RV.
I will never go back to copper, PVC or galvanized plumbing again.
I could not believe how easy it was to use the Sharkbite connectors.
If you've never heard of or used Sharkbite plumbing do your self a favor and research it. Here's the website http://www.sharkbite.com/usa/?gclid=CMqyzvbasrECFYUaQgodJQYA5A
Everything is cut and push together...no glue, no heat, no solder, no putty or teflon tape.
ronfisherman
SE Michigan
Posted: 07/24/12 11:11am Link  |  Quote  |  Print  |  Notify Moderator
If you are going to do more than a few PEX fittings get a crimper and some rings. Makes it much easier and cheaper.
Kodiak Chassis Class C Forum
westend
all over
Posted: 07/24/12 11:29am Link  |  Quote  |  Print  |  Notify Moderator
X2
'03 F-250 4x4 CC
Wills250psd
walnutcove NC
Posted: 07/24/12 11:53am Link  |  Quote  |  Print  |  Notify Moderator
I keep my crimpers and various fitings plus pipe with me all the time.
DavidP
Raleigh
Posted: 07/24/12 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I have an Oeitiker/Pex crimping tool with an assortment of rings. In the long run this may be cheaper but for someone making a repair or a few changes the Sharkbite will be much cheaper and easier. Even though Sharkbite fittings meet code in most cases behind walls, crimping IMO seems more permanent. My crimping tool was anything but cheap at over 70 bucks so for a quick repair Sharkbite is the way to go.
Wills250psd
walnutcove NC
Posted: 07/24/12 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
X2
the bear II
Torrance CA.
Posted: 07/24/12 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I originally was going to go the crimp route but once I saw the crimping tool was over $55 and I only had a few connections to do, the push on connectors made more sense.
I'll ask Santa for a Crimp set for Christmas so I can Sharkbite future projects.
Old-Biscuit
Across the USA
Posted: 07/24/12 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
I'd much rather use Sharkbites (or Gatorbites) then crimping.
So much easier IF/when you want to change anything or have another problem.
Yeah...bit more expensive but I like the fact that you can remove & reuse the connectors.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
othertonka
Stockton, CA
Posted: 07/24/12 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky for sharkbite
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
PikeRoadWarrior
Pike Road, Alabama
Posted: 07/24/12 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
I keep a long length of tubing, plus crimps and a crimping tool, in my tool collection under the bed. A real lifesaver when you have that dripping pipe under the sink...
2004.5 Dodge 2500 Cummins 4x4
2009 Sabre 31BHDS
