RV.Net Open Roads Forum: Class A Motorhomes: Frig stopped working.
 > Frig stopped working.
twainharteartist
Twain Harte Ca
Posted: 07/24/12 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
My refrigerator stopped working. I turned it on the other day and I could hear the ammonia gurgling in the system and it didn’t get cold. I had been using it nonstop for about 16 months then it sat off for about 3 or 4 months. I have removed the frig and have it setting upside down I have been told that will fix them sometimes. The power works so this should get rid of the vapor lock anyone know how long I should let it sit before I turn it over and reinstall it?
SWD
Land of Living Skies
Posted: 07/24/12 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Unlike a compressor type fridge which needs to sit upright for quite a few hours, this absorbtion type unit can be started as soon as you've re-installed it.
Tinstar
McKinney, TX
Posted: 07/25/12 12:38am Link  |  Quote  |  Print  |  Notify Moderator
I'd let it sit 24 hours unless you need it before that. I figure 8 hours might do it if you need it right away.
Never pass up a chance to go somewhere
twainharteartist
Twain Harte Ca
Posted: 07/25/12 12:39am Link  |  Quote  |  Print  |  Notify Moderator
OK but how long should it stay upsiddown before I turn it rightside up? It must take some time for the air bubble to dislodge. Will a day do? I turned it last Sunday so if I try it on Saturday is that enough time? Thanks
twainharteartist
Twain Harte Ca
Posted: 07/25/12 12:40am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys I will let you know how it gos.
Gale Hawkins
Murray, KY
Posted: 07/25/12 12:51am Link  |  Quote  |  Print  |  Notify Moderator
Gurgling can mean your hydrogen has leaked out so the water can boil due to drop in PSI of the cooling unit charge.
Get you an Amish cooling unit option if that is the case.
twainharteartist
Twain Harte Ca
Posted: 07/25/12 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
What is a Amish cooling unit?
chuckftboy
North Florida
Posted: 07/25/12 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
From what I read on the web,gurgling is a indication that there is a blockage and is pretty much not repairable. Usally caused form getting over heated. Good luck. Keep us posted.
2009 Pace Arrow F53 Chassis 2006 TJ Towd
Gale Hawkins
Murray, KY
Posted: 07/25/12 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
David Force seems to do the marketing for Pines RV Refrigeration.
Rickyrocket
Coventry,RI
Posted: 07/26/12 05:35am Link  |  Quote  |  Print  |  Notify Moderator
Go electric,save yourself a long trips worth of cash,flipping it over is a bandaid at best
