RV.Net Open Roads Forum: General RVing Issues: Uneven tire wear on RV/5'er
 > Uneven tire wear on RV/5'er
seattlefirervr
Snohomish, WA
Posted: 07/24/12 11:14pm Link  |  Print  |  Notify Moderator
Over the past few years after regular rotation of tires, I have noticed a significant uneven tire wear on the port/driver side of my RV tires compared to starboard/passenger side. Dual axle setup. Ideas? Fixes? Original tires since 2005 with above average use/mileage.
2006 31' Wildcat QBH,Yamaha 3000EFi Generator
2000 Ford F250 Lariat PSD CC,SB,4WD,AT. aFe Megacannon Airfilter,4" Diamond I exhaust,Custom"Evergreen Diesel"chip,Autometer pillar gauges,BD Torque Converter,ATS Turbo Housing,Wicked Wheel,BD Exhaust Brake,
5ertime
NC
Posted: 07/25/12 02:02am Link  |  Print  |  Notify Moderator
Type of tire would be helpful.....but a 7 year old trailer tire is near record use....without blowout....I would replace all five and see if wear occurs.....since 3-5 yrs is max life of ST s.....
Luke Porter
National Director
Posted: 07/25/12 07:03am Link  |  Print  |  Notify Moderator
You need your tires balanced or axles aligned or both.
What kind of wear?
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
Jayco-noslide
Galesburg,Il., USA
Posted: 07/25/12 10:11am Link  |  Print  |  Notify Moderator
On a trailer, take it to a trailer specialty shop and have them check the alignment. They can realign by bending the axles, probably for several hundred dollars. that corrected my uneven tire ware.
Jayco-noslide
seattlefirervr
Snohomish, WA
Posted: 07/25/12 10:23pm Link  |  Print  |  Notify Moderator
"Transmaster", made in Taiwan. 235/80/16, 5 ply, load range D. The wear is realtivley even all the way across on driver side, but outsides are more worn than middle. Max is 65 PSI, tow them at 63 PSI all the way around. I was wrong on the year, original tires since 2006, not 2005.
