RV.Net Open Roads Forum: Class A Motorhomes: Fantastic fan in bedroom
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Fantastic fan in bedroom
Doug and Cassi Glass
Clifton Forge, VA
Posted: 07/31/12 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Has anybody replaced the basically worthless 4 bladed ceiling fan with a Fantastic fan? I'm curious about the structural framework in the ceiling that might be in the way. I don't want to weaken the roof but need more air circulation back there. Gets warm dry camping in Key West.
Rig is '05 Itasca Meridian 36G.
Thanks.
P.S. Winnie customer service wasn't any help.
ScottG
Bothell Wa.
Posted: 07/31/12 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Yes! I installed one that has the thermostat in it, in the normal ceiling vent. It's wonderful to turn it on when we go to bed and then in the middle of the night after it has cooled down, it turns it self off.
Sorry if this doesn't exactly answer your question but it is a great mod.
Scott, Grace and Wesly
H0NDA eu2000i
Johno02
Lexington, TN USA
Posted: 07/31/12 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
If its a regular 14" vent opening, the Fantastic Fan iwll fin with mo modifications. They are designed for that exact purpose. Most RVs with a overhead vent have the necessary framing already in place. If you have a small fan already in the vent, then you have all the wiring available also.
Noel and Betty Johnson
2005 GulfStream Ultra Supreme, 1 wife, 1 Poodle
desobelman
Camarillo, CA
Posted: 07/31/12 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Doug,
I think you have just a ceiling fan and not a vent in the bedroom. is that correct? I have a ceiling light AND a ceiling vent in my BR, so replacing the vent with a Fantastic Fan would be easy.
If you do have a ceiling fan, I will think that you could install a Fantastic Vent in place of the fan. You would, of course, need to cut a hole through the roof into the BR ceiling for the install. Dimensions and instructions come with the Fantastic Fan. Just make sure you seal the frame to the roof very well. Use a good sealer under the flange and then all around it.
If you are not that handy, go to your local RV service center and pay them to do it. I know Lazy Days is in FL and they have a good reputation. Don't know if the are convenient to you, or not.
Good luck and..............
Happy Trails!
Darryl
Darryl, Carole & Buddy the Wonder Dog
2005 Sea Breeze LX 8375 37' w/3 slides
"The Grand Hotel West"
2008 Saturn VUE, Towed
GS-25512187 FMCA-355241 Dolphin-1901
Fresno Tundra Driver
Fresno,Ca. USA
Posted: 07/31/12 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Did it last month above my kitchen. Fantastic vent is nice upgrade over the stock fans. It is very quiet yet effective with the bigger fan blades. Replacing it took me about 6-7 hours total time. That is probably longer than most but I'm not super mechanically confident. Most of the time was spent taking all the old putty off and cleaning the surface to create a nice seal. I used eternabond tape (2 sided and 1 sided). You can buy the eternabond tape by the foot on ebay so you don't have to go and buy a big 50 foot roll. It really made the job easy and the Fantastic vent company really stands behind their product. Most are designed to be a simple swap for the standard 14 inch stock fan. Good luck!
E.Lee Galik
Dennis M M
Geneva, IL; Tucson, AZ
Posted: 07/31/12 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
As others said, it will fit fine in the standard opening. We have three and love them. Two with rain sensors and the one in the bedroom has a cover so we can keep it open in the rain.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
YC 1
Yuba City Calif.
Posted: 07/31/12 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you are saying you have a fan and would have to cut a hole, which I believe to be correct, then I have a suggestion. Fantastic fans are excellent. They do make some noise. Since your bathroom probably has one of those useless screaming one speed fans you can replace it with the Fantastic model. Now it serves two puropses and any noise is a bit further away and you can run it closer to full speed. With that setup you can still use your ceiling fan. Also try reversing the ceiling fan with this setup. We have two Fantastic vents. One in the bathroom and one in the Kitchen. We can stand the curtains out when we open the small windows in the bedroom. Ours do not have thermostats on this RV and I miss that option that we had on the last one. We can add them but just haven't made it a big priority.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
Sez Hoo!
Athens, Ga
Posted: 07/31/12 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
I love my fantastic fans. A lot of people don't know that they have a lifetime warrenty on the entire fan. I had them ship me parts for my fans free of charge, no questions asked.
Steven & Jane
Jo (ridgeback on the road)
Simon (says)
1998 Country Coach Intrigue
Athens, Ga
Y-Guy
Tri-Cities, WA
Posted: 07/31/12 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Endless Breeze fan from FF that I like, I can set it by the window in our bedroom to either exhaust air or blow in, the soft white noise helps to block sounds without being annoying. I can also move it to anyplace in the coach with a 12v outlet so it comes in handy other places too.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
TGarrett
TN/SC
Posted: 08/01/12 12:01am Link  |  Quote  |  Print  |  Notify Moderator
I'd be interested in seeing a fantastic fan with a motion/moisture sensor for the restroom. That way when someone uses the toilet or shower it would turn on the take out the smells/moisture. But only open when the moisture content is high from showering or someone is moving around the toilet area.
Garrett
2004 Fleetwood Expedition 38N
Full Timer
Toad(still to be setup) 2011 Jeep Rubicon
2nd (to be put on double trailer with 1st when moving) 2008 Honda S2000
