RV.Net Open Roads Forum: Towing: Trailer Tire wear
Search only in Towing
Open Roads Forum  >  Towing
 > Trailer Tire wear
JCher
Arizona
Posted: 08/02/12 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
On May 1st I purchased a new 2011 travel trailer. I have taken three trips for a total of approximately 600 miles. I noticed last week that all four tires are showing abnormal wear on the inner and outer edges. The trailer came with ST205/75R14C tires. The MFG. date is 26-10. I inflate them to 50 PSI which is the recommended pressure on the sidewalls. I have used several different tire pressure gauges to cross check the gauges and tire pressures. The trailer has only been towed on pavement and not above 65 mph. The trailer is currently at the dealer for some warranty work and when I mentioned the tire issue the service writer said that he did not think the tires would be a warranty item. He said something about the way the trailer is turned may be causing the wear. My question is are the tires a warrant item? Also should the tires with only 600 miles be wearing the way I described? I stopped by a local tire store and was told the tires should be replaced. I understand the tire store is in the business of selling tires but will the trailer be safe to tow without new tires.
donn0128
Pronounced Ore-gun
Posted: 08/02/12 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Classic symptom of underinflation. Is that 50PSI as listed on the tire sidewalls?
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
LQuig
Idaho
Posted: 08/02/12 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same problem on my side x side utility trailer. Was told it was because of cheap tires,carrying max load,or close,,,sidewalls give too much,making it look under inflated..but it isn't..
coolbreeze01
Redding, Ca
Posted: 08/02/12 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
If your tires are showing wear at 600 miles, and you aren't overloaded, you probably have an alignment problem, which your dealer should address. Your tires are covered either by the manufacturer or distributor for 3 to 4 years for failures due to defects, but not alignment problems. Good luck.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
tvman44
Southwest Louisiana
Posted: 08/02/12 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problems with the cheap chinese ties that came on our 5er, had the alignment checked and explained that the tires were not over loaded or under inflated and the conclusion was the tires could not handle their rated loaded. Replacing with BF Goodrich Commercial TA's solved the problem.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
johntank
Oxford, Ms 38655 USA
Posted: 08/02/12 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
On this I agree with coolbreeze01.
I have no idea of what kind of warranty that the tires might have.
Francesca Knowles
Port Hadlock, Washington
Posted: 08/02/12 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
From Trailer Tire Wear Diagnosis
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
LQuig
Idaho
Posted: 08/02/12 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
The chart doesn't cover cheap tires with weak sidewalls, that "are" inflated properly..
Chuck&Gail
In the Colorado Mountains
Posted: 08/02/12 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Did you ever actually WEIGH your TT fully loaded? Classis symtom of overloaded tires. Are they the size listed on the plate on the TT sidewall? Are they inflated to the sidewall max pressure?
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Francesca Knowles
Posted: 08/03/12 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Flabby sidewalls is more often related to putting passenger-type tires on trailers. A primary difference between ST tires and P/LT tires is that ST's have stiffer sidewalls. Tires designed for passenger-transport vehicles are actually an important component of the comfort/suspension system and are designed for a "softer" ride. That's inefficient on a trailer.
The tread patterns on passenger-transport tires are usually also wrong for trailers, which only need to follow the tow vehicle. They do so most efficiently with shallow, straight tread-designed tires. The deep, aggressive tread that's required for steer/drive axles interferes with a trailer's straight-behind following action. Fuel efficiency is also affected.
 > Trailer Tire wear
