Cedarhill wrote: If the owner blows out the water system with compressed air according to recommended procedure, there is no use for putting antifreeze anywhere but in the traps of the drain pipes. I don't care what the water tastes like in the traps.
What happens when you get water collecting in a low point? You cannot get 100% of the water out with compressed air!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
Lilliputian wrote: I think it sounds interesting, from a chemical perspective. We're the type of family that eats organic foods, avoids artificial stuff, takes herbs, etc., and the idea of drinking water from lines that have had antifreeze in them is icky to me,
If you use any commercial prepared foods, toothpaste, cosmetics, and even many medicines, odds are you've been ingesting the common food additive propylene glycol. Propylene glycol also happens to be the primary ingredient in most RV antifreeze.
DutchmenSport wrote: What a fantastic way to transport booze across the border! Never though of something like that before!
But to answer the OP's post: nope, never heard of anyone actually doing this.
I put it in a Mercedes windshield washer fluid container when I was in West Berlin years ago. Even flushed everything out really well first. Could not get any windshield de-icer fluid and the Vodka was very cheap at the Class 6 store!
"I think I've heard that people who live where it gets cold can't just blow out the lines and have to use antifreeze everywhere, so it's something I'd want to research better if we ever lived somewhere I had to do that. It's my goal to never live somewhere that cold, though."
That just is not true. Many of us who live in "cold country" use air pressure to blow out the lines in the RV, just like we do with our underground sprinklers!
It works.
In reply to the OP, yes, an alcohol based anti-freeze will work just fine. It is doubtful that much evaporation will occur during cold weather.
Many years ago, some automotive anti-freeze was alcohol based.
Very few people liked it, but it wasn't poisonous.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Aww Haa!! Now we know what, "The Ten Little Bottles Was Really About." If you are too young to know about, "The Ten Little Bottles," ask PAPA, he knows.
Harold and Faye US Navy Retired
2006 Fleetwood Revolution 40LE
400 cat
robatthelake wrote: Ok so RV Antifreeze contains some ethyl alcohol ,but,what is the percentage?
Some RV antifreeze products are 20% ethanol, some are 10% ethanol mixed with propylene glycol, some are only propylene glycol. All of these are mixed with a majority of water.
Ethanol is there for only one reason, because it is cheaper than propylene glycol. I always seek out and enjoy paying more for all propylene glycol antifreeze. It is alleged that the presence of ethanol increases the stubbornness of the aftertaste problem and is harmful to plastic/rubber components.
edited 08/04/12 07:46am by fred42 *
d3500ram wrote: ...and look at the good side of when spring rolls around: just grab a bag of ice and a gallon of OJ and invite the friends over for a de-winterizing party!
That's funny.
06 Dodge 3500,Dually,CTD,Auto,QC,4X4,Torklifts,Fastguns
2008 Northstar 8.5 Arrow, 100W AM Solar
2011 KZ Durango 275 RL 5er
US Navy 1964-1968, 2-Tour Vietnam Vet
downtheroad wrote: I just bought a 2 gallon jug of RV anti-freeze at Walmart for under $4.00.
Man, that must be some kind of nasty vodka to be less expensive than that....
I have never seen a 2 gallon jug of RV anti-freeze in WalMart or anywhere else is this a new thing? $4 for two gallons is a steal.
I did buy -100 boiler anti-freeze at store close out for $2 a jug. Mixed it half and half with water and had enough to last quite a few years.
NanciL wrote: I might just try Margaritas.
then when we arrive in the Florida Keys for our annual snow birding I'll invite the whole camp ground over for de- wintertizing
Jack L
Fill the water tank, 40/50 gallon of hootch better than water we all carry. Just don't tell wife why she can't turn on pump. She has to use only bottled or shore water.
I'll be over and get hammered with all the others. Hell you'll be the most favored guest at the park.
