Iceman31
Gravelbourg, SK, Canada
My Coby system gave up on us last night. I am looking for a replacement that will work with my setup. The speakers are wired into the ceiling. Where can I find a system where my speaker wires will plug into the unit? Current unit is a Coby Dvd-937
Not looking to spend a fortune just want something that works.
2011 Ford F150 XLT 4 x 4 c/w 3.5L & 3.73 - 6spd Auto Transmission
2013 Palomino Sabre 34TBOK-6
2012 Ford Explorer XLT AWD 3.5L
2011 Crestliner Superhawk c/w 115HP Mercury
2003 Sea Doo GTI LE
2012 Can Am Spyder RSS
2007 Yamaha Phazer FX
2000 Yamaha SRX 700
rhingst
Livingston, Texas USA
What is on the end of your speaker wires?
2008 Ford F350 Lariat Crew Cab Powerstroke SRW
2007 Hitchhiker Discover America 339RSB
Iceman31
Just the wire itself. That is what I am looking for a unit that has the ability to plug the wires in the back. Kind of old school but that is what I have.
peaches&cream
Northwest Georgia
I have a Sony that speakers hookup as you describe. Just strip the + & - wire back, push the tab on the system down and insert the bare wire in the unit. I think most Home Theater Units are set up this way so you can make speaker wires whatever length you want.
2005 Holiday Rambler Ambassdor, 36PRT, 330 Cummings
Toad 1995 Miata
Iceman31
I need to replace the DVD receiver unit as the speakers are in the ceiling. I am having trouble finding a unit that has the hookups for the speakers that hook up as mine do.
BB_TX
McKinney, Texas
Don't know what stores you have in Canada. You will need a home theater type system to drive the speakers.
Had the same speaker hookup you describe. I replaced mine with a Panasonic DVD/home theater system from Best Buy. However, I could not a system that did not include new speakers. So I replaced my speakers with the new ones using the existing wiring.
Try any large electronics store and look for DVD/home theater systems. Best Buy had a number of different units from different manufacturers. I chose the Panasonic because it was closest in size to my old one and I had limited space to install it.
TechWriter
Green Bay, WI USA
Then buy the exact same unit. You'll have to get it from Amazon or eBay because the Coby DVD-937 has been discontinued.
The deal with "all-in-one" systems like yours where you get a DVD, FM/AM, and speakers is that the speakers are typically not 8 ohm like "standard" home theater speakers.
So you may experience problems if your DVD-937 uses 4 ohm speakers and you hook up an 8 ohm receiver to them.
The DVD-937 manual doesn't list speaker ohms, but the newer DVD-938 does (4 ohms). The two models might be the same or might not.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
Iceman31
I have been having trouble finding a replacement unit. I see that the 938 has the same hookups as the 937 so I may just order that one.
schneid
In the Wind
Teac
Jensen
Both compact.
OhhWell
As long as the amlifiers are rated to push a similar load (4ohm Speakers), then just get any system you like. Clip the wires for the speakers that come with the new system and splice them to your existing speaker wires. Just stay consistant with the polarity.
Every one of those all-in-one systems that I have examine have run 4 or 3 ohm speakers. Most use digital amps like in car stereos. Not the purest sound but they have no problem driving low impedance speakers and get more volume that way.
2008 Keystone Sprinter 299BHSS
2003 Ram 3500 CC DRW 4x4
