RV.Net Open Roads Forum: I finally took my Wolf Creek 850N to the scales
 > I finally took my Wolf Creek 850N to the scales
Mello Mike
Mesa, AZ
Posted: 08/08/12 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Last month I took my F-250 to the scales. With just me and a full tank of gas my truck weighed 6,720 lbs. The advertised weight of my 2011 Ford F-250 is 6,686 lbs, so the actual weight was pretty darn close with the difference being my own personal weight. With my 10,000 lb GVWR this gave me roughly 3,300 lbs of payload.
I thought I was all set when I bought my lightweight Wolf Creek 850 truck camper. With a certified wet weight of 2,328 lbs and a GVWR of 3,300 lb, I had an extra 1,000 lbs with which to play. That 1,000 lbs would've be fine for just extra cargo, but I ate into that 1,000 lb figure by installing extra options for my camper like an air conditioner, an inverter, a combo storage bunk, a fantastic vent fan, a flat screen TV, and three roof top solar panels. All those extras are great to have, but they really add up when it comes to weight.
After loading up the truck last weekend with my fully loaded camper, 2 additional passengers, a large inflatable boat with electric outboard engine, food, and camping and fishing gear, the total weight of my truck was 10,800 lbs. The total was a little higher than I expected. I expected to see a figure around 10,000 lbs. So, yes, I'm overweight but not by much.
So what's the moral of the story? If you haven't weighed your truck and camper yet, fully loaded, I can almost guarantee that they will weigh more than you expect. I went out of my way to get the lightest possible camper that fit our needs and I'm still overweight. Fortunately, with a rear axle GAWR of 6,100 lbs, my rear axle and tires are more than beefy enough to handle the extra 800 lbs. I don't always bring the boat and our college-age boys on our trips so that figure will be around 3-400 lbs less for a total of 4-500 lbs over the GVWR.
* This post was edited 08/09/12 11:04am by Mello Mike *
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
2BLAZERS
KEIZER, OREGON
Posted: 08/08/12 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Truth there!! and me too
2011 Dodge Ram 3500 4*4 Black dually Laramie 4.10 gears
2011 Arctic Fox 1150 Drybath
2009 Polaris RZR w/fun parts
2011 Polaris Sportsman 550 XP EPS w/stuff
2006 Polaris Sportsman 500 w/stuff
1977 K5 Blazer 1 ton modified
2007 Toyota Camry Hybrid (her car)
daveshan
Durango Colrado
Posted: 08/08/12 10:50am Link  |  Quote  |  Print  |  Notify Moderator
6720lbs?? My F-250 (in sig) weighs in at 7750 with a full tank and a 35lb dog in it. Didn't think the diesel and 4wd would make that much difference.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
Lots of Stuff
WA. USA
Posted: 08/08/12 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the overweight club.
My truck has a GVWR of 9200 lbs.
My truck with me, wife, camper and all generally weights out around 10,000 lbs. Highest weight was 10,080 lbs.
My truck hasen't seemed to suffer and the original 160,000 mile brake pads still have over 50% life.
The only place that being over GVWR is illegal is British Columbia, Canada as I understand it.
How big can my pick-up camper or RV trailer be on my ½, ¾, or 1 tonne pickup be? Do I need brakes? Do I need a special driver’s license?
The camper, when loaded on to the pickup or when you tow a trailer behind the pickup, can not exceed the manufacturer “Gross Vehicle Weight Rating” (GVWR) or the “Gross Axle Weight Rating” (GAWR). The ratings can be found on the driver’s side door post.
Link to Quote scroll down to question 16.
gov.bc
It's not illegal in the states and My state has even licenced my truck to weigh 10,000 lbs.
* This post was edited 08/08/12 11:14am by Lots of Stuff *
DG
03 Chevy Silverado Regular Cab 2500HD 4X4 Duramax
04 Lance Lite 915
kerry4951
East Central Pennsylvania
Posted: 08/08/12 11:35am Link  |  Quote  |  Print  |  Notify Moderator
When we were up in Canada two years ago I came across an open scale with no one around. I drove on and got the weight in kilos and had to transcribe it over to lbs. I was shocked to see how much over weight I was. Amazing since the truck handles the TC like a dream. I am also a full fledged member of the "over weight club".
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
Mello Mike
Mesa, AZ
Posted: 08/08/12 11:51am Link  |  Quote  |  Print  |  Notify Moderator
It does. That's the main reason why I didn't go with a 4x4 and one of reasons why I didn't get a diesel.
AKPWDR8
Chugach Mtns, Alaska
My name is Tim, "And I have a weight problem" Ha 2500/825 loaded the Diesel,4x4-short bed really hammer being creative on the scales
2011 Chev. 2500 HD Duramax CCSB
2012 Lance 825
daveshan
Durango Colrado
Posted: 08/08/12 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Can't live without 4x4 up here several months a year and won't live with a gasser at 7000'+ it's a trade off I'll gladly take. But if I was back at sea level in Southern CA and not towing a 7000lb trailer while the camper is on I'm sure I'd think differently
SoCalDesertRider
SanDiego, CA, USA
Posted: 08/08/12 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
That's the reason I keep preaching to buy the F350 instead of the F250 when someone wants the diesel crew cab 4wd. The F350 has about 1500 lbs higher GVWR and about 800 lbs higher RGAWR than the F250 for '05-'11 model years.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
RichieC
Gig Harbor - Cave Creek
Posted: 08/08/12 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
That's 8-percent overweight.
I've always considered anything less than 10-percent overweight is probably safe and within the trucks handling and braking safety margins.
Weighing it is a good point though.
