RV.Net Open Roads Forum: Travel Trailers: Black Water Hold
 > Black Water Hold
jjhill
Foxboro, MA
Posted: 08/12/12 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry if this has been asked and answered before.
Should you keep your black water valve closed until it is almost full or leave it open while on site?
Thanks in advance.
Jack
Wind River
wyoming
Posted: 08/12/12 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Keep the valve closed until tank is at least 2/3 full. Empty the black tank first, flush the tank 2 or 3 times until the water runs clear. Empty the grey tank.
2003 GMC 2500HD 4x4 Duramax/Allison
2004 Jayco Jay Flight 25RKS
Equal-i-zer Hitch, 3502 Ultra Fab Tongue Jack
Twin Honda 2000i w/parallel kit
Eycom
32043
Posted: 08/12/12 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
You should keep it closed until you need to dump. If the tank is below 2/3 full, add water before dumping. Be sure to add back a couple/three gals. after dumping so the tank doesn't dry out.
RVn Full-time
fordsooperdooty
Posted: 08/12/12 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
If you leave it open, the solids will go to the bottom of the tank and the water will flow out of the tank, not the solids. You'll get really nasy clogs in the system.
On the other hand, letting the tank fill up some using plenty of flush water when you flush the toilet...then pulling the handle will flush out the tank and get rid of the (as they say in Star Trek) the nasty Klingons!
anaro
Mebane, NC
Posted: 08/12/12 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
As others have said, do not leave it open, drain as needed, flush it well (until runs clear, using the geo method helps with this), then close it and leave a few gallons in the bottom to prevent the dreaded stone mountain from building up. We also only dump our grey tank when it is full. We dump the grey tank after the black tank to help get any yucky reminants out of the sewer hose.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
usmc616
Orange County, New York
Posted: 08/12/12 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Always closed. Only open it before dumping the grey water tank.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
joeprinter
Fayetteville, NC
Posted: 08/13/12 05:13am Link  |  Quote  |  Print  |  Notify Moderator
Black closed until emptying an leave gray open, but close grey for sometime for dumping black for rinse.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
gaymeadowsman
Montgomery, Alabama
Posted: 08/13/12 07:20am Link  |  Quote  |  Print  |  Notify Moderator
If there is ONE thing I truly dislike about our Surveyor it's the fact that it has separate valves/outlets for the holding tanks. I generally use a "Y" connector at the sewer inlet at full hookup sites(can't rinse black hose)until until I remove from trailer and I use an Anti-backflow valve on an old Black washing machine hose.
If I pull to a dump station I use single hose and have to move from one valve to the other. And I always hose down the area to dilute any drips I can't avoid.
John
Ted
2007 Surveyor SV291
2010 Chevy Silverado Ext Cab LT
2011 Hyundai Sonata GLS
jjhill
Foxboro, MA
Posted: 08/13/12 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info. All good ideas and will use as suggested.
 > Black Water Hold
