RV.Net Open Roads Forum: General RVing Issues: Debate on what is "level"
 > Debate on what is "level"
Page of 7
CA Traveler
The Western States
Posted: 08/15/12 08:54am Link  |  Quote  |  Print  |  Notify Moderator
You'll know when it's to far off level. The typical refer needs to be level within 3 degrees and maybe more in the other direction.
3 degrees is a 5" drop across a 8' RV. You won't be comfortable with that slope on the floor or anywhere else.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
road glide
Angels Camp, California
Posted: 08/15/12 09:29am Link  |  Quote  |  Print  |  Notify Moderator
parametric wrote:
I am amazed how many used the ultimate standard of level - the bathroom door!!!
X2..LOL
2003 Safari Sahara 350 Cummins ISC Allison 6 speed
Model 3753 - Triple Slide
2002 Jeep Liberty Limited 4x4 tow vehicle
Willow, our 5 year old female White Boxer
Kittykath
Minnesota
Posted: 08/15/12 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes placing a ball in the middle of the floor works. Just jack it up on the side the ball rolls to.
MetalGator
Posted: 08/15/12 10:06am Link  |  Quote  |  Print  |  Notify Moderator
nevadanick wrote:
Set a beer in the doorway and when it looks like the beer is level in the bottle your done. You can now drink the beer and not worry about anything else.
This is the correct answer!
restlesswind
Fulltime
Posted: 08/15/12 10:53am Link  |  Quote  |  Print  |  Notify Moderator
For those of you that mentioned that a half bubble off is just fine.
My wife insists that I have been at least a half bubble "off" for many years.
My question is...
Should I try to set the trailer up so that it is a half bubble off in the other direction?
If I get it so that the bubble shows level,would I still be a half bubble "off"?
Using marbles on the floor...Won't work...lost them a long time ago!
( Maybe I've spent too much time out in this heat!)
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
paulm999
Pala, California
Posted: 08/15/12 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
No matter where you put a level, you will get a differant reading in each part of the RV. After I level the RV, I expect nothing to be perfect. Since the fridge is usually in the middle of the RV, I open the the fridge door half way (45 degrees) and full (90 degrees). If the door does not move in either position open, the RV is sufficiently level.
Cummins12V98
on the road
Posted: 08/15/12 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
I used a lazer level and adjusted the rv to where the 4 corners of the bottom of the frame are the same distance to the lazer light. Now that the rv is PERFECTLY level I use a very high quality adhesive and glue one HOPPY level "perfectly level" next to the door for the landing gear and one on the front under the overhang on the 5er. I put tape on them in the level position and let the glue cure. Now I can get my rv perfectly level easily every time!
Using a little plastic level in a frig is a waste of time.
If you don't have access to a lazer level use a 4' carpenters level on the bottom of the frame.
You can buy lazer levels fairly cheap these days and there are many other uses for them. Guys, like when the wife says the picture you just hung is crooked, just whip out the lazer!
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
camperpaul
Wherever I park my travel trailer
Posted: 08/15/12 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
You can buy laser levels fairly cheap these days and there are many other uses for them. Guys, like when the wife says the picture you just hung is crooked, just whip out the laser!
I knew a guy who did that a few years ago and discovered the house wasn't level. That is when the fun started.
He did the measurements and the math and it came out that all he had to do was place two jacks under the main beam in the basement and raise it 3 inches. When he did, it cracked the plaster on every wall in the house.
After 5 years of evenings and weekends he finally got all of the damage corrected.
A month later his company transferred him to another city.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
Cummins12V98
on the road
Posted: 08/15/12 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
I had a couple guys work for me like that, they did not last long!
I used a professional Hilti lazer level. Even the cheap ones can be accurate, set the level on one side of the rv and get it level. Then take the level to the opposite side and check. If not exact average how much it is off. Once you get the levels right it really is easy to level up your rig.
mr. ed
Madison, SD (but usually elsewhere)
Posted: 08/15/12 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
For newer Dometics, the instructions state that if the RV is comfortable enough to be lived (no noticeably sloping walls or floor) then the fridge will be OK. Older units were more critical.
That being said, I strive to get most of the bubble centered in the level, which I place on the floor of the freezer. When I level my RV the fridge level takes precedence.
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
Page of 7
