Brandon327
Mississippi
How long will tank last in about 40 degree weather?
2013 gmc 3500 hd cc Drw 4x4
2014 palimino sabre 36 qbok
bikendan
Napa, Cal.
way longer than your battery, that runs it, will.
reality is that a single battery will last one night of using the furnace.
we've gone an entire camping season and used the furnace half the time and only used one 20lb. tank, along with all the other propane things.
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever(RIP ), 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
Brandon327
Mississippi
I am just trying to decide if swapping my ac unit out for a heat pump is worth the extra cost.
Jim Cindy
Northcentral, PA
Brandon327 wrote: I am just trying to decide if swapping my ac unit out for a heat pump is worth the extra cost.
If you have a heated basement/storage area and are going to be in below freezing temps, you will need to use the furnace also in order to keep things from freezing. Heat pump will not direct heat to those areas.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Brandon327
Mississippi
I think I am just gonna add a heat strip to my current unit.
stickdog
29.820224, 81.94542
If it doesn't drop below 40 a couple 1500 watt heaters should work. We used 4 30# tanks last winter in Austin TX area, only used the furnace when temps were going below freezing. We also use are stove and oven extensively.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Eycom
32043
I agree with stickdog. I have the heater strip in the a/c and don't use it. It's loud with the a/c fan and does a great job of heating the ceiling area while my feet are on the floor. It will eventually warm up the camper over time, but who wants to listen to all the noise. A relatively silent ceramic heater suffices far better and I can instantly direct the heat. When the temps drop below freezing, I'll run the furnace to reach the tanks.
RVn Full-time
ArcticDodge
Sammamish, WA
40 degrees? Who runs a heater when it's above freezing??
Just kidding. Propane is consumed at a healthy rate by the furnace. Your insulation quality of your rig and how warm you need to be will be the biggest factor of propane consumption. Living in a northern climate I don't mind waking up to an inside temp of 52 degrees and bumping up the thermo a few degrees to warm up.
If you are plugged in to power, I'd run a space heater but having a heat strip available is an option if needed.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400
1 Wife 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 23 years to retirement!!!!
KD4UPL
Swoope, VA
I got an electric space heater at Walmart for $19.95. It does a great job of heating the camper in temps like the 40s. I don't camp much when it's below freezing but if I did I would run the furnace to heat the tanks.
bailer6334
Prescott, AZ
We were in the Phoenix area last winter and averaged about 20 gals of propane usage every 4-5 weeks. This was for the water heater and furance only. Everything else was on electric.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
