RV.Net Open Roads Forum: General RVing Issues: Water heater fire.
 > Water heater fire.
DE88ROX
West Michigan. The other West Coast
Posted: 08/22/12 07:12am Link  |  Quote  |  Print  |  Notify Moderator
So im at MIS this past w/e enjoying 5 days of tailgating during the NASCAR race.
Wife went to wash dishes after breakfast this past Saturday and was complaining that she wasn't getting hot water. I told her that its a 6 gallon tank and to give it about 10-20 minutes to heat up. I'm not really sure how long it normally takes since this is the first time I used it "on demand" Normally its always going.
After about 20 minutes and no hot water, I went around back to see what was going on and I noticed flames inside the control panel through the vent. I went to open it and after burning my hands I noticed flames coming from the vent on the venturi tube as well as the area where the ignitor is. Needless to say I have a lot of melted wires and other things back there now.
I was hooked up to a Honda EZ3500 generator. But wasn't running since I figured the battery would be enough to get the ignitor going and I had the water heater set to gas.
This trailer has been nothing but a pain in the @#$ since the day I bought it new. And when I see other with the same trailer I ask them if they have had any problems with theirs. When I told this fellow race fan about my issue he said it was my fault because i had it hooked up to a generator while running gas and to read my manual.
Well all my paper work is in the TT and that is now at the dealership where I bought it. We got home from MIS and quickly unloaded it and I took it in.
I'm wondering if there is any truth to what this guy told me?
My service writer said that one of the wires is supposed to melt when exposed to flame and upon doing so, is suppose to shut the entire system down so it stops trying to reignite. Mine kept trying to reignite, so something failed in the system.
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
AtomicChicken
Central Louisiana
Posted: 08/22/12 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I fail to see how this would be any different than if you were hooked up to 30 AMP shore power on a pedestal. What model water heater?
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
jimtoo
Perfectly Great!
Posted: 08/22/12 08:16am Link  |  Quote  |  Print  |  Notify Moderator
There was a recall on some water heaters for fire danger. You might check it out.
They installed a guard around the flame area.
Happy Camping
Drive Safe
Jim & Bette
Kerrville Sweetheart XI Rally
George West Storyfest, 1st Sat of Nov.
04 GMC 3500, CC,Dually,Duramax,Allison
CB Radio, MaxBrake, Turboliner, Ride Rites
08 Bighorn by Heartland, 3055RL, Trailair Pinbox, Equaflex.
1fastdad
mo.
Posted: 08/22/12 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Most of the time the heat tube is blocked by mud dobbers or something.
lawnspecialties
Garner, NC
Posted: 08/22/12 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Ditto. Was this "fellow race fan" holding a can in a huggie?
2011 Ford F450 4X4
2011 Cyclone 370C
pianotuna
Regina, SK, Canada
Posted: 08/22/12 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I'm sorry your purchase does not please you.
Running the generator has nothing to do with the gas operation of the water heater.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
JJBIRISH
Butler, PA, USA
Posted: 08/22/12 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Sound like flash back caused by a partially or completely blocked burner tube…
The thermal cut off is supposed to shut down the gas in extreme heat situations but there has been some known problems with that not happening…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
bsinmich
Holland, MI
Posted: 08/22/12 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
If that isn't covered by warranty then maybe it is covered by your insurance.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Chris Bryant
DeLand, Florida, USA
Posted: 08/22/12 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Had you ever run it on LP? On an Atwood, there is a thermal fuse for that reason, which obviously didn't work.
You might file a report at http://www.saferproducts.gov
-- Chris Bryant
My RV Service Blog
The RV.net Blog
old guy
Oregon (pronounced Or e gun)
Posted: 08/22/12 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder if the guy who was writing about a recall was talking about the recall on frig's last year? I do not know of any recalls on water heaters that needed a guard installed.
