patsslab
Wadsworth, Texas
I have a hankering for a Lance 1161 but I have a Ford One Ton with single rear wheels and Air Lift air bags on the rear. Do I really need a dually to carry the Lance 1161 when the truck is equipped with the air bags?
1995 Ford Power Stroke 94 Northland 9.5
May God Bless Your Travels
LeeT
WA
YES!!!
With the 1161, you have a heavy load. Your tires can't handle it. I believe that 3400# is the strongest E tire out there, which is actually reduced to about 2800#(?) pounds in a DRW configuration.
Your 1 ton SRW can only carry 6800# on the rear axle (if you have the right tires), where as the DRW can carry over 10,000#.
2006 Jacyo Jay Flight 27.5BHS
1998 C2500HD X-Cab LB, Rhino Liner, 16k Dual-pivot Husky Hitch, Prodigy Brake Controller
Prev: 2003 Northern Lite 10-2000CD
Go Cougs!
bluefishgary
Middle River,MD
YES, YES, YES, get a dually its to big for SRW
1994 ford F-350 4x4 srw
2003 lance 1030 w/everything
A.M.S.A. 872 N.C.B.B.A.6411
305/70/16 Nitto Terra Grapplers
I caught a fish once -it was fun
Rob55
Wabash, IN, USA
You will be grossly overwieght. Lance recommends a dually with this unit. I don't think a reputable dealer would load you up with one.
I just bought a new f-350, dually. We also love the 1161, just looked at one last weekend. But very concerned about the weight and size. We are looking at a 1071.
I think about as big as you should probably go is a 1010 or 1030.
My humble opinion.
Good luck.
2006 F-350 Lariet dually diesel, Lance 1121 pulling a Lund/Honda fishing rig.
Greg B
Minnesota
Your going to be severly overloaded with a 12' camper on a SRW truck.
Lance states the dry weight of the 1161 at 3495 pounds. Fill it with water and propane, load with supplies for a weekend, and you'll easily be close to 4500 pounds.
This load will max out most duallys.
04 Dodge 1 ton dually, Cummins, auto, quad cab, 4x4, SLT, Sport, Reese Titan V
04 Lance 1161, TV/DVD, high efficiency A/C, Honda EU2000
dndj
NorthWest Oregon
Absolutely, positively, YES.
vectorcnc
WV
Yes you will have to have a DRW truck period. I belive if you try this what will happen is blow out after blow out.
To be honest no dealer that is reputable would mount it. If they did and Lance found out my guess they would no longer handle Lance.
edited 01/28/04 07:08pm by vectorcnc *
frankcarey
Melbourne, FL & Twitchell Lake, NY
I just bought an 1161 and I just bought a dually. It's the only way to go. I learned this here and also from a Lance dealer.
1999 Ford F350 Lariat V10 ext. cab DRW
2002 Lance 1161 with most options
saxeT
Lake Tapps WA
My 1161 loaded for travel has a rear axle wt just over the axle rating of my dually.... good thing I got 4 tires back there.. I think its too much for a SRW... JMHO>>>
00' F350 PSD CC DRW 4x4 Auto front reicever w/scooter rack
05' Lance 1181
Torklift Tiedowns and Super Hitch 48", Fastguns
Equal-i-zer wt dist hitch,
Firstone Riderite bags, R9000 frt/RSX9000 rear
moisheh
North America
Good Sam RV Club
dndj: Are theose Alcoa mags on your truck? Thanks
