RV.Net Open Roads Forum: Technology Corner: want out? with new garman 2620
RV.net
 > want out? with new garman 2620
GUY H
SUMMITVILLE IN USA
Posted: 12/12/04 03:59pm Link  |  Print  |  Notify Moderator
I just got my new garman 2620 and am trying to learn how to use it? Iam 80 years old and pull a tt but have a little trouble finding my way around useing the maps! so my daughter would not let me out till she was sure i would return home! so i thought i would give this a try and see if it will always bring me home and so far it does! now i want to go to california and i can't make it go were i want it too the 2620 wants me to take hwy 70 and i wish to take hwy 65 out of indy to 40 the south route do to bad weather? any help on this would be nice as i can use all i can get! thanks,
G.H.M
brobox
Sunny SW. Florida
Posted: 12/12/04 04:04pm Link  |  Print  |  Notify Moderator
Easy fix. Pick a city in the dircetion you want to travel along I-65, then pick another one towards 40 and set that up as a Route. After you get past the bad weather then put in Calif. and away you go.
Have a safe warm trip.
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
joemyers
Houston, Tx, USA
Posted: 12/12/04 05:51pm Link  |  Print  |  Notify Moderator
After you set your destination, just go the way you want to and it will automatically recalculate and correct itself.
creeper
Richmond Hill, Georgia
Posted: 12/12/04 06:26pm Link  |  Print  |  Notify Moderator
Just drive the road you want and it will adjust accordingly or use the preferences to fine tune road selection. IF that doesnt work just use waypoints along the way you want to go.
Travel Blog
96Bounder30E
Orange County, CA
Posted: 12/12/04 06:43pm Link  |  Print  |  Notify Moderator
set your end point and then add a "VIA"......along the route you want to take, it will then calculate your route..........easy!
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
FloridaNomads
Old Town, Florida USA
Posted: 12/12/04 06:50pm Link  |  Print  |  Notify Moderator
Guy.. with my Magellan and Streets and Trips map, I just ad stops along the route I wish to take. It forces Streets and Trips to calculate my route using the stops. Don't know if your map system will allow that. But as one posted says, you can use waypoints to do the same thing.
Ray K4DAB and Judy KB5GXI Wallace
29.68555N 083.03008W
2002 Dura/Max/allison super crew 4x4.
Reese 16k Kwik slide
Montana 2001 2955RLS two slides.
RCtime
Rancho Palos Verdes, Ca.
Posted: 12/13/04 07:57am Link  |  Print  |  Notify Moderator
Guy
You really have a great gps, but sometimes these new fangled contraptions can get some getting used to.
Eric had it right. use a via.
After you have your route where you want to go push on the MENU button. When the new screen pops up press on the ROUTE icon. on the new screen pop up in the center you will see an icon that say add/edit vias. Touch this icon and you will have two choices. If you pick map, you can use the screen to show what road or city you want to go to. touch the screen where you want and then the little check mark in the upper right hand corner.
If you choose the 2nd choice of your ad vias selection a screen pops up and you have all the choices of RECENT FINDS-ADDRESSES--CITIES ETC.ETC. Save your route and its there for you if you want it again.
Play with it a bit at home plugged into the wall outlet and after you do it a few times its really easy.
a tip-- when I use the map to put in a via reduce the map scale so it shows a lager area until you find it, Then enlarge it again where you want the via to be. I have to do this because my fingers are fat and not too precise if its not enlarged. Or as someone else said. just turn onto the hwy you want and it will recalculate. I just did this recently though and the problem with this is , it will sometimes try to return you to its origional direction, after 4 or 5 attempts to get you back to origional direction, it will decide you really dont want to go that way and recauculate the way you want. This can be annoying.
* This post was edited 12/13/04 09:14am by RCtime *
Ron
2002 34HD Winnebago Journey DL, Cat. 330
2004 Honda CRV - Garmin 2610
Great wife & Cavalier King Charles Spaniel
TT/N
brobox
Sunny SW. Florida
Posted: 12/13/04 09:06am Link  |  Print  |  Notify Moderator
RCtime,
Great tip, I have been looking how to do this also. Now I have two ways to change the route I want to take. Trying to force the 2610 to take a Hwy. that you want to stay on sometimes does not work. At every crossroad the Garmin wants to take you back to the Interstate instead of staying on the scenic route you want to take.
Thanks,
mibearbait
Lansing, Michigan
Posted: 12/13/04 06:45pm Link  |  Print  |  Notify Moderator
This is not related to your question, but is a good little tip for finding HOME. Set your home as a way point, change that waypoint name to Home. Next time you want to find home, press the FIND key twice and the GPS will ask you if you want to find Home, press yes and it will plan a route to your home.
As for your original question, I agree with the people that are telling you to select via points. The via points must be selected in order that you want to travel. Keep in mind that in most instance the GPS will route you through the city. As example, taking 65 to St. Louis to pickup 44 west will route you through the center of St. Louis, which is not bad as long as it isn't rush hour. You can select via point around the city and the GPS will route you around as planned. I just used my 2610 last week to drive my parents to Mesa, AZ and followed pretty much the route you want.
2004 Newmar Dutchstar
Grand Cherokee Toad
Garmin 7200 GPS
Always remember that you are unique, just like everyone else.
