RV.Net Open Roads Forum: Roads and Routes: best route through or around chicago.
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > best route through or around chicago.
land yacht 35
rapid city sd
Posted: 03/13/05 06:33pm Link  |  Print  |  Notify Moderator
I need some advice. coming from the north on I 90 and going to elkheart indiana. need the best route through chicago or around chicago. I was through there once 10 years ago and I took I 90 and man that sucked. thanks
Tim Jenks
ssniper1000
Plainfield, IL
Posted: 03/13/05 06:57pm Link  |  Print  |  Notify Moderator
I drive from Joliet, IL to Hammond, Ind. several times per week (not your route). There is no good route through Chicago, but there are good times. Avoid Thursday, Friday and most importantly avoid rush hours. 3:30pm-6:30pm and 7:00am-9:00am (my experience). If you time it right it won't be that bad. If you decide to try I80 via rockford (39/51) then check out the website http://www.in.gov/dot/div/specialprojects/borman/
This site is for the borman expressway project which happens to be under construction for the next several years.
I'm sure others that drive your exact route will have more ideas.
Milt
Climax MI
Posted: 03/13/05 07:02pm Link  |  Print  |  Notify Moderator
As far as I know that's the best route.
You'd be taking I 90/94 south and on the south side of city
get on Chicago skyway it goes right to IN tollroad which goes
east to Elkhart.
thy raised the toll on the skyway after the first of the year and I don't know what it is now.
Milt
avan
Naples, FL
Posted: 03/13/05 07:05pm Link  |  Print  |  Notify Moderator
Well, most everything is going to suck getting around Chicago but I think I'd take I39 south out of Rockford to I80 and then take I80 east. Not a great alternative but you probably won't hit the worst of traffic till you get to the I80/I294 split and it should start easing a bit east of the IN line. And of course you'll want to plan it so you're running counter to the rush hour traffic which will eliminate some of the cars running with you and the trucks.[emoticon]
Winnebago 30C Aspect
Saturn Vue
My 2016 Summer Trip
bertturner
Near Chicago
Posted: 03/13/05 07:06pm Link  |  Print  |  Notify Moderator
If you are coming from Rapid City, work your way down to I-80 far to the west of Chicago. There are many routes to do this. If you are coming from some other point to the north, don't keep it a secret.
Even with the construction on the Borman, it is usually better than it was a couple of years ago.
Albert
stickdog
Somewhere, USA
Posted: 03/13/05 07:38pm Link  |  Print  |  Notify Moderator
Here's a second for avan's route.
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
tcsmith
Centennial, Colorado, and Charlottesville, VA USA
Posted: 03/13/05 08:14pm Link  |  Print  |  Notify Moderator
Yeah, no route is great, but I-80 is better than some. We go from Colorado to Ohio on I-80 a couple times a year. Still no good route through Chicago, but if you watch out for rush hour(s) it's better than most.
Tracy & Jennifer Smith + 5 Boys (no room for a dog!)
1999 Dodge Ram Maxi-Wagon 3500 and 1999 8300 Trail-Lite TT
dancoppins
Michigan
Posted: 03/14/05 05:49am Link  |  Print  |  Notify Moderator
When you get to the Chicago Skyway...USE IT. You will eliminate the majority of the bad tie ups. It goes to the toll road.
AirForceRet
Mishawaka, Indiana
Posted: 03/14/05 08:45pm Link  |  Print  |  Notify Moderator
We do the chicago trip a couple times a year with the travel trailer. I90 and the skyway is the shortest and often the less traveled of the many alternatives. The skyway is under new management so be prepared to pay a little more than you used to pay, but it's worth it as there always seems to be less traffic on the skyway (probably because it's not free).
And if you get caught in stop and go traffic, it's usually stop and go everywhere, so the "shortest" route often tends to be the fastest route too.
If you can make the journey after 7:00 pm or so, you will probably have a decent traffic flow, but don't expect too much, Chicago is busy all hours of the day and night!
If you need a place to stay near Elkhart, you may want to consider Eby Pines. There's a KOA just West of Elkhart if you want to be close to shopping malls, restaurants, etc.
Good luck...we'll be making our next trip through Chicago in June (yippee)!
Roger, Dawn, and Roxie
Air Force Retired
Life Member - Good Sam Club
2017 Four Winds 26B
AirForceRet
Mishawaka, Indiana
Posted: 03/14/05 08:49pm Link  |  Print  |  Notify Moderator
oh yeah...and if you decide to skirt west of chicago, then across 80...be prepared to sit in stop and go traffic there too! there is quite the bottleneck of traffic at 80/90/94/65 south of lake michigan that is often times at a complete standstill (literally).
late night travel is beneficial going this way too! although this route often times isn't too bad midday.
