INSAYN
NW Oregon
Thought I would reconstruct some info from my website for use on this forum. Some of you probably have already seen this, but this way it can be added to the sticky that Brad has been working on.
I will just copy and paste some of the info directly into this post.
Here ya go..
I decided that I needed to up the Battery AMP hours for my new truck camper from dual Group 24's, to dual Group 31's. The Snowriver camper has a very user friendly battery box design, that allows the owner (me) to install larger batteries in the same space as smaller batteries. If you have looked at very many brands of new and older brands of truck campers, you will see that they usually only allow you enough room for one battery, and usually fit a Group 27 or less at that.
So, I set out to find a battery tray that can support two heavy (68lbs each) batteries. I wanted the luxury of being able to service the water levels while the batteries were still in the camper, and not have to lift them out to do so. I did find one shelf that would have worked, but the cost was way out of my desired level, so I get to design and build my own.
With some help from my buddy Mark and his new (used) sheet metal brake, and another friend Mike that does powder coating on the side, I was able to design and finish exactly what I set out to do.
This is what I had to start with, only there were two of these small Group 24 batteries.
Here it is closed and then in the full extension at 12" out. Perfect for a 13" long battery.
Bolted into place, and then extended out to show the workings.
Batteries placed in the tray and the tray locked into place, the door will just close and all is good. The batteries actually fit better if put in the tray sideways. I may go ahead and flip them around and make sure that the furthest battery back has the water caps towards the center. I just like the looks of this way better.
Here the batteries shown extended pretty much all the way out, and in the last picture, it is clear that reaching the water covers will be a cinch.
Oh! And the grand total in parts and powder coating was a whopping $27. The full extension slides are rated at 100lbs a pair and each battery is 68 lbs, so it all worked out great.
Hope this give someone some insight and motivation to build their own parts if your anything like me and like to create.
INSAYN
1997 F350 CrewCab PSD 4x4, auto.
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, 2005 40HP Yamaha 2-stroke O/B.
BobsYourUncle
Surrey, BC Canada
Hey thats really great!! Nice pics! I am currently pondering ideas for adding a pair of 6V golf cart batteries to my TT. You have given me some good ideas. Thanks
Bob
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
YrekaRVers
Yreka, CA.
What a slick looking unit and oh so functional. Cool!
I want to leave this earth calmly and quietly in my sleep like my grandfather and not like the other three screaming passengers traveling with him in his RV.
Don M.
Saginaw TX
Nice info and post. Wish more folks would post "homebuilt" projects!
Don M.
Saginaw TX
No RV yet.
*Home of the Y2KOTA*
maritt3
No. Colorado
Great post (and project!) Insayn! Appreciate the time and effort to share your work with us. Thanks...
'05 Dodge 3500
'04 Northern Lite Ten 2000RR
tom_kat
way upstate new york/lake george area
looks good,wish they sold those trogan batterys around here.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
BobTowne
Fairfield, CA, USA
Great post of an interesting job well done.
Thanks
GreatWhite
2004 Dodge Ram 3500 Quadcab Dually
2004 Alpenlite Santa Fe 1150
John H
Kansas City Mo.
With a smile and an extended hand....."You did well, Man !!!!Thanks for the insite. John
John H
PR Connection
Powell River BC
Insayn
I to own a snowbird 9'6". I am currently using 2 6 volt batteries. They are interstate 220 work aholic's. Would these still work in your tray?
Thanks
Dan
2006 3000SL26 Bigfoot Class C
320 Watts Solar With Bluesky 2000 Regulator
Four 6volt U2200 Batteries
2000 Watt PSW Magnum Inverter
BradW
Flat Rock, Alabama
Added to the Projects and Ideas Thread
