RV.Net Open Roads Forum: Folding Trailers: Power Lift systems, good or bad?
 > Power Lift systems, good or bad?
te13
f
Posted: 02/15/06 12:13pm Link  |  Print  |  Notify Moderator
I am looking at buying either a fleetwood or rockwood/flagstaff pop-up tent camper. I understand that both have a Power Lift system (to raise the camper) as an option. Perhaps a dealer option. But I have heard mixed comments.
Does anyone have any experience with either trailer using the Power Lift System? Are they reliable? Can I raise and lower either with a prower drill? Any help would be appreciated.
2manytoyz
Central FL
Posted: 02/15/06 01:17pm Link  |  Print  |  Notify Moderator
I had heard bad things about the factory electric system, but that was from a decade ago. Don't know if they are more reliable or not.
However, I used an electric drill and a Socket Jenie to raise my roof. Details on this setup at this link.
Had that Popup for 9 years, sold it and the drill to a neighbor. I'll soon be in the market for another Popup, and will likely go the drill route once again.
Robert
Merritt Island, FL
2007 Rockwood TT 2502
Equalizer Hitch
2010 Ford F-150 FX4 -w- Max Tow Package
Yamaha EF2400iS
http://www.2manytoyz.com/
Freeman2004
Central CT, USA
Posted: 02/15/06 01:18pm Link  |  Print  |  Notify Moderator
While we have not had our unit out a large number of times, the power lift has performed flawlessly. Other then when I forgot to hook up the battery!
It makes opening the unit so easy as mine is both an up and an out!
Scott & Karen
2004 Fleetwood Monterey
2003 Ford Ranger Edge in Very, Very Red
PopUpTom
West Tennessee
Posted: 02/15/06 02:38pm Link  |  Print  |  Notify Moderator
The Fleetwood acc. lift has a poorly designed electical connector that gets mounted in the back bumper (Montery excluded). It is the unreliable link in the system. I'd take a trip to Radio Shack to wire in something better if I had one. Hopefully they've fixed it by now.
My 14v DeWalt worked (when fully charged) until I mounted the bike racks on the roof. I tried my 4amp 3/8 corded Dewalt, it doesn't have the torque. Looks like a 24v or 1/2" corded is your best bet, but both will break your wrist if you're not carefull.
* This post was edited 02/15/06 02:46pm by PopUpTom *
2001 V6 Highlander, 2002 Coleman Sun Valley, Single Bar WD, Tranny Temp Gage, Prodigy Brake Control (update 2010: we've moved outside of Memphis, the PUP has a new home, and we're pondering (2014: still pondering) a larger TV and a hardside)
KS Poppy
Lenexa, KS
Posted: 02/15/06 05:19pm Link  |  Print  |  Notify Moderator
No problems with the Rockwood Power Lift System. About 25 nights out and it worked every time. EXCEPT, when you have a dead battery. Any power lift system that I know of works off of the battery. It's a DC electric winch. One time we had a bad battery and I used jumper cables to the TV to run the lift. Rockwood manual lift is under the plastic winch case.
2005 Ram 2500HD 4x4 QC Hemi 4.10 LSD
2 other Jeep "toys"
06 Keystone Zeppelin 291
05 Rockwood Rhino 256G HW - Gone
PattieAM
Maryland
Posted: 02/15/06 06:20pm Link  |  Print  |  Notify Moderator
My dealer was not negative, but did feel I would be better putting money on something else. My rental friend said it is just something else to break when you feel you need it most! Another PUP owner said use either socket genie or drill or good old manual crank.
Camper Carl
Van Nuys, Calif.
Posted: 02/16/06 02:04am Link  |  Print  |  Notify Moderator
Hi There,
I have a power lift system on my pop up that I did myself for $50.00 from buying a winch motor (2000 lbs) and about 8 hours of work. It works great. I have a bad back and it is really nice to just push a button and in about 1 minute it is up and going. I understand that the power lifts from the dealer run about $700.00 installed. That sounded a little high to me.
Carl
If you think nobody cares if you're alive, try missing a couple of
payments on your RV.
2007 campouts: 2
Days: 6
Miles Towed: 475
-O-U-
Sarasota, FL
Posted: 02/15/06 06:49pm Link  |  Print  |  Notify Moderator
We love ours - and it sure does the trick in making the neighbors jealous!
Me, the DW Forum addict
DH, "He who can fix anything"
Abby, the camping wonder dog
Harvey, the "Happiest Dog in the Whole USA"
2003 Thor Wanderer Wagon 207 Toy Hauler,
Reese 12,000lb WD hitch
2005 Ford F250, V-8, SuperCrew Lariat Superduty
