RV.Net Open Roads Forum: Class C Motorhomes: Power Supply
 > Power Supply
locustthorngolf
Iowa
Posted: 03/05/06 05:45pm Link  |  Print  |  Notify Moderator
Would anyone have the wiring diagram for a Phillips
Power converter/battery charger Model PC-401-A-1
serial number 3-55555-5-316 This site is great, a lot
of nice members giving a lot of good information
Thanks all
locustthorngolf
Iowa
Posted: 03/06/06 07:59am Link  |  Print  |  Notify Moderator
I guess my question can't be answered. Can anyone direct me to
where I can get information on this inverter. I can't seem to
find anyplace on web for Phillips Power Inverters. It also gives
me a company on the unit that says B-W Manufacturers, Inc.
721 N Webster St. in Kakomo, Indiana but they aren't there in my
yellow pages. Any help would be apreciated. Thanks again
Westronics
Redmond, WA
Posted: 03/06/06 08:12am Link  |  Print  |  Notify Moderator
How about starting at:
Philips Consumer Electronics
1-888-744-5477
Monday - Saturday 7:00 am - 11:00 pm EST
Sunday 8:00 am - 11:00 pm EST
Excluding major holidays
They should be able to re-direct you if necessary.
2002 Jayco Greyhawk 24SS, Camera, ScanGauge, Inverter, Airtabs, Portabote, SeeLevel II, Tireman valves, Xatnrex Battery Monitor, Aero-flo vent, Trik-L-Start, XPS Rib, Chains, Lil' Stanker, Be kind to septic systems Ford: 1-800-444-3311. RV Tires
hilbiles
Missouri
Posted: 03/06/06 08:39am Link  |  Print  |  Notify Moderator
IF it say's B-W Manufacturers Inc. try this site. Look at what they show and see if your matches model numbers may be different.
http://www.parallaxpower.com/index.htm
j-d
Sunny Florida USA
Posted: 03/06/06 10:09am Link  |  Print  |  Notify Moderator
That ParallaxPower site sure helped me! I've been looking for info on a B&W 3240 for awhile now. It seems the Magnetek name is woven into this story somehow. THANKS!
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
locustthorngolf
Iowa
Posted: 03/06/06 12:07pm Link  |  Print  |  Notify Moderator
You gave me the information on Philips and my converter is a Phillips
with 2 l's Maybe thats where the problem is. I did send an email to
ParallaxPower and waiting for info. Thanks a bunch for the help!
hilbiles
Missouri
Posted: 03/06/06 12:11pm Link  |  Print  |  Notify Moderator
From what I have gathered. B-W was bought by Parallax. Magnetek Is a manufacture of the actual bords used in these converter, I think.
locustthorngolf
Iowa
Posted: 03/06/06 03:24pm Link  |  Print  |  Notify Moderator
A BIG thanks for the information on Parallax. They got right back with me
on the wiring diagram and im in business.
hilbiles
Missouri
Posted: 03/06/06 05:39pm Link  |  Print  |  Notify Moderator
If you need parts try this website. They have alot of parts ect. for old converters along with a bunch of other stuff. I fixed my old B-W converter and it is working fine. Clost me $10. instead of buying a whole new converter. Might not be as hi-tech as the new ones but it does it's job. and if you spend the time to adjust them correctly they work just fine and won't blow your batt's.
http://www.ecovantageenergy.com/catalog/subcat141.htm
MELM
GA
Posted: 03/08/06 04:35pm Link  |  Print  |  Notify Moderator
For your info...
It started as Phillips, then became Phillips/B-W Manufacturing then B-W Manufacturing where some changes were made in the line of the linear converters. B-W Manufacturing sold to Magnetek, and they basically changed the labels and added the Q series. Basic design and model numbers didn't change; but some parts were updated or changed. They bought the Triad Utrad ferroresonant line and basically kept those model numbers and added a new line and the electronic switching converters.
Parallax bought that and soon discontinued the linear and ferroresonant lines; but they still have support for them. They only sell the switching converters now.
That's how he got a Phillips schematic from Parallax.
I've learned a lot about them from posts on this forum from members; and I've got a B-W Mfg linear converter that does great (after I adjusted it for the correct charging voltage).
Mel
 > Power Supply
