RV.Net Open Roads Forum: Truck Campers: Truck Bed Wiring
 > Truck Bed Wiring
BradW
Flat Rock, Alabama
Posted: 03/10/06 06:20pm Link  |  Print  |  Notify Moderator
Lance plug and pigtail I salvaged from our old truck.
Three more holes in our new truck bed.
Lance plug.
Ford 7-pin plug wires and Lance plug pigtail.
Final wire splice.
The downside of wiring the bed plug this way is the +12V wire that Ford runs to the 7-pin RV plug is on the small side.
Ford Wires at 7-Pin Plug:
Orange = +12V (positive)
White = -12V (negative)
Yellow = Left Turn/Stop
Green = Right Turn/Stop
Brown W/White Stripe = Running Lights
Brown W/Green Stripe = Back-Up Lights (Note: May be Black W/Green Stripe on some trucks. Thanks F350OilBurner)
Blue = Electric Trailer Brakes
* This post was last edited 08/15/07 07:24am by BradW *   View edit history
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
wsdepa
Raleigh, NC
Posted: 03/10/06 06:48pm Link  |  Print  |  Notify Moderator
Why wouldn't you use a No 8 or larger wire from the truck battery. Your charging would be much more effective. Actually you should use a No 4.
Regards.
2006 F-350 S/C 6.0 DRW 4x4 3.73, Airlift,Energy Suspension bump stops. 2005 Lance Max 981,Polar Cub a/c, both awnings, EU2000, Yakima box.
http://truckntravels.blogspot.com/
Get in shape America - walk, run, paddle or ride a bike!
BradW
Flat Rock, Alabama
Posted: 03/10/06 07:35pm Link  |  Print  |  Notify Moderator
Regards.
I agree. A larger +12V and -12V wire would be better. Especially if the camper has a 3-way frig.
Brad
vanbikehorse
Green Lane, PA
Posted: 03/11/06 05:24am Link  |  Print  |  Notify Moderator
I did a 10 gauge charge wire to match what was coming from my camper pigtail. I put it from the left truck battery, through the isolator, and then directly into the pigtail contact (eliminates the run to the back of the bed and up again. Don't forget to do the same to the ground wire (I also left the original 10 gauge ground wire there; can't be too grounded!)
2005 Chevy 2500HD SB X-CAB,4X4,G-80,D/A,ALCOA Wls,265/75R16E, Air Lift Sure Set, SuperSprings, RS9000x, Curt 14108.
2003 Alpenlite Laramie w/X CAB & Polar Cub A/C, Happijac FM, EU-2000.
2000 Brenderup Baron TC Horse Tailer
1996 Arab Endurance Race Horse
DSeckt
Cedar Point , Northern Ohio
Posted: 10/26/06 03:11pm Link  |  Print  |  Notify Moderator
I also took the Lance plug off my old truck and want to install on our new one.. The problem I'm having is identifing what color wire goes to what post on the lance plug.... This plug doesn't come apart so I can see whats what... Is this wiring standard and if so what color wire on the lance plug corresponds to the ford colors??
Dan
06 Ford F350 Dually/ Crew/ PS / SB
Lance 820.......It's all I need!!
CumminsDriver
Newcastle Calif.
Posted: 10/26/06 06:41pm Link  |  Print  |  Notify Moderator
BradW wrote:
Regards.
Brad
Can the plug and receptacle on your camper handle anything larger than 10 gauge wire?
Rich
'09 Dodge/Cummins 6.7 3500 Quad Cab DRW SLT Laramie Auto, Timbrens & Overload Bump Stop Spacers; Tork Lift Super Hitch, Tiedowns and Fastguns, ExtremeAir 12 Volt Air Compressor
'04 Arctic Fox 990; 91 Jeep Wrangler ARB's TeraLow 4.5" Rubicon Express Lift
 > Truck Bed Wiring
