RV.Net Open Roads Forum: Tech Issues: Onan Generator Tune-up Specs Please
 > Onan Generator Tune-up Specs Please
Bud Weaver
Sunny Southern California
Posted: 08/29/06 09:16pm Link  |  Print  |  Notify Moderator
I need a couple of tune up specs for my 6.5NHE Emerald-III Onan generator.I was able to discern that the valve last is .005/.013 In./Ex. and the spark plug gap of .025".
But, can anybody tell me the gap for the breaker points and the float level dimension for the carb.?
The help is greatly appreciated!
Thanx,
Bud
kg5388
on the long road of life
Posted: 08/29/06 09:32pm Link  |  Print  |  Notify Moderator
almost all points for onan set at .020 including yours i'm not at work and don't have my service manuals with me but i think your valve lash is off and the carbs are realy not rebuildable and are best replaced or left alone if it's running god
Bud Weaver
Posted: 08/29/06 09:40pm Link  |  Print  |  Notify Moderator
I pulled the valve lash specs from Perr's small engine website. Hmmmm well, if you can (or whomever) can you give me the valve lash specs too? It runs great but it blows black smoke when I fire it up cold. The choke is hooked up and operates freely as does the butterfly. The pull-off diaphragm is also fine and working well. It just throws alot of fuel into the airstream when you go to fire it up.
BTW, it is a 6.5NHE-1R/26100A (spec A) genset
Many thanx,
Bud
kg5388
Posted: 08/29/06 09:43pm Link  |  Print  |  Notify Moderator
thanks for the model and spec letter i will look them up at work and post them when i get home tommorrow
Bud Weaver
Posted: 08/31/06 11:06am Link  |  Print  |  Notify Moderator
kg5388
Posted: 08/31/06 08:08pm Link  |  Print  |  Notify Moderator
sorry i'm taking friday thru tuesday off and had to work late yesterday and today to help get all the inshop units done so the inshop tech can have my truck this weekend
spark plug gap .025 gas .025 Lp
point gap .016 gas .021 Lp
valve lash intake .005 exhaust .013
