henchman
Cardinal, Ontario
As well as used motor oil, tranny fluid, brake fluid.
Ian
1991 Winnebago Warrior 30eu
OLD RIG
2006 Chevy Uplander 3.5l
2005 Jayco Sport 165 18' 3500lbs loaded
Putnam WD w/800lb bars
Acar friction type sway control
Hoppy digital display brake control
BALANCED tires! (Please everyone, balance your tires!)
AZPops
Wherever the Job takes us...
Before you receive conformation on what to do, tell your brother in law not to start the engine. I would keep the gas isolated in the tank, after which for peace of mind I would do as recommended by Big Katuna and BobMary8101.
One thing, at least your brother in law had the courtesy and yayos to call you right away! Now if he will take ownership of his mistake and make it right(accept responsibility of the cost for repairs if needed).
I will definitely watch this thread. Good luck...
LUeno
tom_kat
way upstate new york/lake george area
5 gallons to 95 gallons should not hurt it,we had a driver that would add about 5 gallons to each 55 gallon tank for more power but it did do engine damage after a lot of miles around 150,000 but he did it on every trip not a one time mistake thing.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
CaBoy
Junction City, OR USA
Like others have said, I would seek professional advice. If they said OK, I would feel much better adding some lubricity enhancer likes Howes or one of the many other good products on the market. Good luck.
The older I get, the better I used to be.
1997 Prevost by Country Coach
470 HP Series 60 Detroit / 6 SP. Allison
2005 Jeep Grand Cherokee Toad
Same Co-Pilot for 46 years
2 Boston Terriers, Scout & Mia
djevans
Tennessee
CaBoy wrote: Like others have said, I would seek professional advice. If they said OK, I would feel much better adding some lubricity enhancer likes Howes or one of the many other good products on the market. Good luck.
I would definitely contact CUMMINS before starting the engine.
That said, if you really agree with some here, that a modern, computer controlled, precisely built and metered diesel engine, is OK to run with 5% gasoline, go ahead. I wouldn't without discussing it with CUMMINS. Period....
Now THAT also said, my absolute first thought was the same as CaBoy's. I'd put several gallons of Howes or a similar type of lubricity enhancer in the fuel tank and put a tube in the tank and blow air in there to make "lots of bubbles" to stir things up. Now way I'm risking the possible wear issues of fuel with no lubricant.
Again though, call CUMMINS and ask.
If you would though, "please" tell us the outcome and recommended resolution.
note: I would let the tank set overnight following the "stirring process."
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - HONDA Element
350hp Cummins ISC
2006 GL1800 HONDA GoldWing
- - - P i c t u r e s - - -
"HOPE" is not a strategy . . .
weasel4
Alberta
in2dp4u
throw a quart of 2 cycle engine oil in the tank and you should be fine.
BTC
Bear461
Winter Haven, Florida
My neighbor is a diesel mechanic - I accidentally put about seven gallons of gasoline into my 35 gallon diesel tank on my Dodge. He advised to add a bottle of Lucas fuel injector cleaner and then drive the vehicle. When I got down to three quarters of a tank to top it off. I did this twice and never noticed any difference in the way the vehicle has run. At the time I made my mistake, the engine had about 5000 miles. It now has over 50000 miles and it runs like a top - consistently averaging over 10 mpg towing a 15,000 lb. fifth wheel. Don't sweat that small amount of gasoline!
in2dp4u
Found this article.
MCrankyPants
Dayton OH USA
Bear461 wrote: My neighbor is a diesel mechanic - I accidentally put about seven gallons of gasoline into my 35 gallon diesel tank on my Dodge. He advised to add a bottle of Lucas fuel injector cleaner and then drive the vehicle. When I got down to three quarters of a tank to top it off. I did this twice and never noticed any difference in the way the vehicle has run. At the time I made my mistake, the engine had about 5000 miles. It now has over 50000 miles and it runs like a top - consistently averaging over 10 mpg towing a 15,000 lb. fifth wheel. Don't sweat that small amount of gasoline!
Ditto...don't ask me how I know
5 gallons of gas into 95 of diesel...I wouldn't give it a second thought.
2007 Teton Experience Sunrise pulled by 2003 Dodge 3500 Cummins HO 6-spd. 4x4
'61 VW Double-Cab
2oldman
Moses Lake
After all the discussion on here about lending out your rig.. oh well, sounds like no big harm done.
