RV.Net Open Roads Forum: Class C Motorhomes: Can't Find My Battery Isolator
 > Can't Find My Battery Isolator
carringb
Corvallis, OR
Posted: 08/27/08 01:23pm Link  |  Print  |  Notify Moderator
Four Winds may use the trailer charge circuit to charge the coach batteries. The trailer charge circuit will be connected any time the ignition is on. The rental I used last year worked this way.
1) Make sure the trailer charge relay is installed in the power distribution box under the hood.
2) Check the 40 Amp trailer charge XL sized fuse in the same box.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Dusty R
Charlotte Michigan 48813
Posted: 08/27/08 06:32pm Link  |  Print  |  Notify Moderator
Pnichols wrote,
"I wonder how many Winnebago (.... or other MH's with direct-connect battery solenoids with a Ford chassis) owners have this happening and are not aware of it because they do not have a monitoring voltmeter on their dash to tell them? They are then sometimes, but not always, faced with arriving at their camp site with partially depleted coach batteries and wondering why "their coach batteries aren't performing well".
I "THINK" that this may be caused by something in the Ford alternator's sensing electronics whereby they are getting "tricked" somehow into sensing a chassis battery voltage that is too high to need any charging voltage applied from the alternator. Somehow my cycling of the coach battery bank's disconnect switch may be serving to correct this sensing/logic error."
My comment,
We have an Itasca 24V. That relay quit working on a trip this past spring, it would open and close but no power would flow through it. Yours may be heading the same way and will quit soon.
Sorry pinchols, I didn't do that right.
Dusty
* This post was edited 08/28/08 05:52am by Dusty R *
RVWithTito
Poulsbo, WA, USA
Posted: 08/27/08 11:19pm Link  |  Print  |  Notify Moderator
Thank MNTundraRet, Pierrem, and pnichols for the useful feedback. Sounds like what I've located is what I need to test. It is, in fact, located on the right side of the engine compartment under the coolant like you said pierrem.
I'll try testing the house battery side of the solenoid while the engine is running to see if the charge voltage goes up. If that doesn't work. I'll try flipping the battery disconnect switch as pnichols recommended.
Tito
2007 Four Winds 31F Class C; Ford E450 Chassis; 250 Watts Solar;
RV Solar, Towing, DIY and Tips on my website RVwithTito.com
Watch My Video Tips at YouTube/RVWithTito
pnichols
Santa Cruz Mountains
Posted: 08/28/08 12:13am Link  |  Print  |  Notify Moderator
Tito,
Please let us know what you ultimately discover is the problem.
Maybe the strange thing I'm seeing is the same and I'd really like to get to the bottom of it.
Phil, 2005 E450 Itasca 324V Spirit
2snobrdz
Punta Gorda, Fl
Posted: 08/28/08 07:29am Link  |  Print  |  Notify Moderator
Perhaps if you make a call to the manufacturer they have the prints on every unit and where things were put. At least that works for my 2006 Coachman Concord E450
2008 Tundra 5.7
2004 Keystone Springdale 25'
2 cats Riley and Casey
1 Beautiful wife
Camped in every state in the continental USA (incl Alaska)
RVWithTito
Poulsbo, WA, USA
Posted: 08/29/08 12:34am Link  |  Print  |  Notify Moderator
I had a chance to test it out tonight with no success. What I thought was the solenoid (under the coolant) appeared to be a relay attached to the emergency start switch (see picture).
I tested the voltage on the chassis side with the engine running. It read a charge voltage of around 14.2V. The house side remained at 12.6V. The house side would go up to the charge voltage only when the emergency start switch was pressed. I was able reach around and hit the switch with my right hand and feel the relay in the engine compartment with my left hand click over. I also toggled the battery disconnect switch to see if that did anything. Unfortunately there was no change.
I'm wondering if I even have a battery isolator. I'll see what the manufacturer says.
Thanks for all of the help. This is a great forum.
-Tito
Dusty R
Posted: 08/29/08 05:36am Link  |  Print  |  Notify Moderator
I think that the emergency start and the battery isolation relay is one in the same.
Dusty
