VE7EDL
Port Coquitlam,British Columbia,Canada
I just installed 6 Michelin LTX M/S tires at Costco, they filled them with Nitrogen at N/C and said they would adjust the pressures everytime I take my camper off and on, I thought that was great service.
2004 GMC 3500 D/A LLY Duramax Crew cab LB
2004 Corsair 10'4" Slide
Torklift tie downs with superhitch
Firestone Airbags
milo12
CA
I have worked in racing and aviation and they have different reasons for using nitrogen.
In racing it is done for predictability of performance and it helps maintain pressure in the tire longer. A racing slick is nothing like a car tire. The rubber on the sidewalls and tread is extremely thin. This is necessary to keep heat buildup down at high speeds. The problem is with such thin walls is normal air will migrate through easier than pure nitrogen.
In aircraft it is primarily for fire protection. Compressed air is extremely flammable.
In a normal street car it is just a gimmick, but if you can get it for free go for it.
My Outfitter Apex 9.5
wnjj
Cornelius, Oregon
2oldman wrote: Been discussed a lot on here:
Nitrogen posts
fordsooperdootydieselsmoker wrote: Nitrogen molucules are larger than oxygen molucules Hmm.. since N exists in a gas in its elemental form, I guess it would be called an atom, not a 'molucule'. Your explanation is a good sales pitch but nonsense.
Sorry, N2 and O2 are both molecules and N2 is indeed larger when in comes to escaping from tires http://www.getnitrogen.org/pdf/graham.pdf
TC John
Chihcago
milo12 wrote: I have worked in racing and aviation and they have different reasons for using nitrogen.
You can get it for free if you purchase new tires...and they will adjust them for free...of course out on the road its different..
I just wanted to know if anybody had any real world monitoring....my truck according to my tire sensors does wander even from tire to tire and of course from hot to cold..
BradW
Flat Rock, Alabama
My neighbor, Amedeo Avogadro IV, told me to keep using air.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
Wheel Estate
Emery, S.D.
wnjj wrote: 2oldman wrote: Been discussed a lot on here:
Nitrogen posts
so after topping off my tires a few times I would have N2 for free???
Rick & MaryAnn
we accompany, a beagle, sir Cody, drive '06 Phaeton
SMI brake stopping a Jeep liberty toad
SoCalDesertRider
SanDiego, CA, USA
Try Hydrogen istead. It works much better and it's lots of fun.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
wnjj
Cornelius, Oregon
Wheel Estate wrote: so after topping off my tires a few times I would have N2 for free???
That what I was thinking. If you never fully deflate your tires, they should end up with more and more nitrogen.
For the record, I think any difference is irrelevant for auto/RV use.
milo12
CA
BradW wrote: My neighbor, Amedeo Avogadro IV, told me to keep using air.
Brad
Brad - That is hilarious.
gm412
Belmont, CA
Good Sam RV Club
I run 60lbs empty and 80lbs loaded and can take the camper on and off several times a month. I just stick with air. Do not have time to run around trying to find nitrogen.
