If you count the nights we have electrical hook ups then divide them by the amount of propane we would save it would take 25 to 50 years to payback the $250.
Others may have electrical hook ups more often than we however.
Lots of Stuff wrote: If you count the nights we have electrical hook ups then divide them by the amount of propane we would save it would take 25 to 50 years to payback the $250.
realter wrote: In the information for the Northstar Laredo, the water heater is $180, and the heater with 110v is $415, so the difference looks like $235.
I suspect that some of the difference here is that the $180 heater is a standing pilot model and the $415 unit is a DSI. A DSI without electric heat is in the $300 range.
I don't think it would be worth it, UNLESS you winter camp. I wish I had it for that reason. I like to stay at Whistler BC to ski through the winter, I have to leave my water heater running all the time because I don't want to freeze the tank. Through out the rest of the year, I start the water heater in the morning, then shut it off after it is up to temp, this will stay hot most of the day and saves propane.
2004 GMC 3500 D/A LLY Duramax Crew cab LB
2004 Corsair 10'4" Slide
Torklift tie downs with superhitch
Firestone Airbags
