RV.Net Open Roads Forum: Truck Campers: steps / stairs over trailer hitch?
 > steps / stairs over trailer hitch?
txtrigger
Posted: 05/05/09 10:01pm Link  |  Print  |  Notify Moderator
I searched the archives for a while tonight, and could not find what might work for us. We have a 9.5' Shadow Cruiser TC, and pull a horse trailer behind. The door of course, lines up direct with the hitch. The acordion type steps did not work, as I could not extend them to the ground with the horse trailer hitched, and I leave it hitched 99% of the time when we are camping. Right now, I have a folding platform that just barely spans over the top of the hitch, and then I strap a second small step stool on to it, and then use the whole thing to climb into my camper. Did I mention it is a 4x4, so a tad higher than some? Looking for something else, that is very stable, will clear the hitch, and goes high enough for our taller camper. Anyone have photos of what they use? Thanks so much
wnjj
Cornelius, Oregon
Posted: 05/05/09 11:22pm Link  |  Print  |  Notify Moderator
We use a 3-step version of this Little Jumbo ladder:
My brother's camper doesn't have a step bumper so he uses the 4-step version:
(The hand hold bar folds down against the front out of the way.)
budman1964
So Michigan
Posted: 05/06/09 01:21am Link  |  Print  |  Notify Moderator
where can you get these steps
SamB4
Calgary,Alberta,Canada
Posted: 05/06/09 08:30am Link  |  Print  |  Notify Moderator
Google is your friend
LittleLadderStore
I have looked for something like this for some time. I have folding steps which work fine when the camper is on the truck, but I need a three steps when off the truck. Most three step stools I have looked at have a safety bar across the top which would be in the way of the door on the camper. If this ladder's safety rail can be folded out of the way, then I would buy this.
Sam
'09 Ram3500 4x4 Quadcab
'04 Northern Lite "Northern 8.5"
'98 Rage Ski boat
stevenal
Newport, OR, USA
Posted: 05/06/09 08:42am Link  |  Print  |  Notify Moderator
I try to park with our boat trailer angled a bit to the left. Since the camper door is offset slightly to the right, the scissor steps extend over the trailer tongue to the ground. Discovered this worked by accident one day.
'98 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
BrandonR
Oregon
Posted: 05/06/09 09:46am Link  |  Print  |  Notify Moderator
I jackknife my trailer just enough so the scissor steps will clear the tongue.
Brandon Reed
Albany, OR
wnjj
Cornelius, Oregon
Posted: 05/06/09 10:21am Link  |  Print  |  Notify Moderator
LittleLadderStore
Sam
Just squeeze the two handles you see just above the top step and it tips forward and down. My brother just drilled the rivets out and removed his completely.
I've found plenty of uses for this ladder around home and for reaching things up high on the sides of the camper (like the range vent cover latch).
sutak
Harrowsmith, ON, Canada
Posted: 05/06/09 10:24am Link  |  Print  |  Notify Moderator
Here is something you may be interested in. One step is mounted on the trailer hitch and the other step is attached to the extension.
extension.
larry.
Another option is to park with the trailer slightly jacknifed. Then stairs could reach the ground.
* This post was edited 06/09/09 06:32pm by an administrator/moderator *
2001 Chev K3500 dually, LT, CC, 8.1L, Ally 1000
1998 Bigfoot 2500, 10.6
txtrigger
Posted: 05/06/09 11:19am Link  |  Print  |  Notify Moderator
extension.
larry.
Now this is something I can dwell on, and see if I can have made up for our rig. I can not always jacknife the rig enough, as we often park at horse events, with limited parking, and we have to stay pretty much straight. Anyone else with something like the above?
46 Woodie
Elfin Forest, CA 92029
I don't know exactly what would suite your needs but I am ordering an item from Cabelas for about $35.00 that goes under the ball and provides a step on either side of the coupling while the trailer is on or not.
2005 Ford F350 Lariat crew cab SRW 6.0 4WD,Donahue suspension, air bags, bump stops, tow beast, Toyo AT's
1999 Lance 9500 11'3", Trimetric with dual 12 volts
2003 Interstate 6x12 enclosed trailer
2007 KTM 525EXC
1946 CJ 2A
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
