RV.Net Open Roads Forum: Tech Issues: Fridge Fan Install Wire Question
 > Fridge Fan Install Wire Question
Page of 5
Tech Issues Related Tips
EllieThomas
Redding, California
Posted: 05/12/09 11:14am Link  |  Quote  |  Print  |  Notify Moderator
It works with the door open. I can't see it when the door is closed But, I closed it and opened it real quick and it was still going strong, not winding up.
I didn't look real close to find the darned door switch to test it "closed". Will look again tonight after work. Does anyone know where it is?
Ellie
Redding, California
2006 Jayco Jayflight 20BH
2006 Chevy Silverado Duramax with Allison
ksg5000
Oregon
Posted: 05/12/09 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
In my fridge if you listen closely you can hear the fan running with the door closed. The location of the door switch varies depending on the model of your fridge .. but finding it should be pretty easy - just a button or lever which moves when the door opens or closes. In a Dometic RM2852 its a lever located directly in front of the light on the right side.
Kevin
screaminjlew
Hanford, Ca.
Posted: 05/12/09 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Ellie
Does you fridge have a light set up like the picture of mine? if so, splice into the black wire.
JLew
My wife said it's either her or my bike...."I sure am going to miss her!"
04 GMC Duramax Diesel 4X4 EC w/ MBRP exhaust Autometer pyro and boost gauges
03 Thor Wanderer 26tb, 2-t-105's PD9260 charger
03 YAmaha Banshee
03 Yamaha Blaster
04 Suzuki Z250
deandec
El Dorado Hills, CA
Posted: 05/13/09 11:10am Link  |  Quote  |  Print  |  Notify Moderator
I also ran both wires from that fan to my door switch. The fan only runs when the refrigerator is on and the door is closed. You can test that result with the refrigerator on,door open, and by pressing the door switch to turn off the refrigerator light. That is when my fan turns on.
I ditched the alligator clip thingy.
Dean
95 CC Magna, Jeep GC
EllieThomas
Redding, California
Posted: 05/15/09 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
I only have two red wires and two black and white wires. I mean to say that the wire is black and white.. two of them are that way.
I cannot use the door switch to turn off the light. I did just find out from a friend that I could run a magnet under the switch and it will turn off. I had looked everywhere for a way to turn off the light with the door open so I could check it.
My fan runs whenever I put the alligator clip on the fins.
Ellie
ksg5000
Oregon
Posted: 05/16/09 11:53am Link  |  Quote  |  Print  |  Notify Moderator
My fan runs whenever I put the alligator clip on the fins. Ellie
If your door switch doesn't turn off your light then I suspect your door switch needs to be replaced/fixed. You really don't want your light running when your doors closed - its a heat source which will diminish the efficiency of your fridge and also suck down your battery power.
EllieThomas
Redding, California
Posted: 05/16/09 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
I found it. It is a magnet... there is no button or switch for me to hold in to see if the light goes off. I put a magnet under the top of the fridge where the door meets and voila! the light turns off.
I would have never guessed it but a friend told me to try it and he was correct.
The fan runs when the light is off. So, I'm good to go.
Ellie
ryanallie1
Magalia, Calif
Good Sam RV Club
Posted: 05/16/09 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
I have the very same fan. Even if you hook it up to a hot lead all of the time. No Biggie. Just install a simple rotary on/off switch to the fan housing. That way you can control when you want the fan to run. In cooler temps, you really don't need to run the fan. Its the really hot days that you have to worry about. Since we mostly Dry/Camp most of the time, I like being able to choose when I want to run the fan. Good Luck. Happy Camping. Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 66-67-68,& 70-71
jkhnc
Cary, NC
Posted: 05/16/09 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
chi6488 wrote:
You guys are lucky you can install these fans. I have to use the $15 walmart fan and I do not think it works as well moving air.
After 6 days I have frost built up on my fins which I am sure makes it not work as well.
I have a newer norcold so I cannot figure out how to install and neither has the seller of this fan
Richard (eBay seller of the fan I believe you and I both own) is working to figure it out. I have a 2008 Jayco with a Norcold N61 series. I have not been able to find a wire that stays hot once the door is closed. I have sent Richard/eBay'er the wiring diagram from Norcold and he is really trying to help make it work. Anyone here able to take a look at the diagrams Norcold N61 (maybe power will have to come from the door (?) and advise how to successfully install this fan to run with the door shut? Much appreciated.
screaminjlew
Hanford, Ca.
Posted: 05/17/09 12:45am Link  |  Quote  |  Print  |  Notify Moderator
I have the thetford model# N611 and if you go back to the second page of this thread posted a picture of my setup and I have a detailed description of which wires to splice into.
JLew
Page of 5
