RV.Net Open Roads Forum: Truck Campers: generator ?
 > generator ?
Truck Campers Related Tips
Haifisch
Silverdale WA
Posted: 05/12/09 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Honda 2000 and it will run the Penguin AC unit on my camper.
Capt Eddie
usa
Posted: 05/13/09 07:24am Link  |  Quote  |  Print  |  Notify Moderator
I have two of the Honda with the Parallel. It is a big problem to get them both out of the boxes, set them on the ground hook up the wires, crank them both up. Next time I will just push a button. My though now is that if I can't afford another generator for other duties, I can't afford to go RVing.
Mooney
Santa Barbara, Ca
Good Sam RV Club
Posted: 05/13/09 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Wrasle congrats on the new truck and camper! You might have room for the Honda EV 4010.
'08 Ford F550, Lariat, Link Air Suspension, Roll-A-Long Conversion, Twin Turbo 6.4, TorkLifts, SuperHitch, "Monster Duty Truckasaurus"
'09 Host Everest, Dual Pane, AM Solar, Link 1000,Prosine2.0,Tank Htrs,Honda EV4010,HD Motosat,Wave 6.
Host Everest Photos
claymcc
Casper, Wyoming
Good Sam RV Club
Posted: 05/13/09 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Wrasle Castle wrote:
claymcc wrote:
Congrats on the new rig!
I don't have an opinion on the generator (I've got a Class A with a built-in Onan that works flawlessly, but no generator on my AF 860) but do have a question about the 117DBL -
Can you get in the camper, and into the cabover, with the slides in? I've been thinking about trading the Winnebago and the TC in on a larger TC, but since I often use the TC for road trips, not just camping, not being able to access the unit without putting the slides out is kind of a dealkiller -
Thanks,
- Clay
There is NO acess into the camper with the slides in but that wasn't as big issue for us. It only takes a few seconds to open the slides.
Well damn - beautiful campers though! Thanks for the info -
- Clay
Near Casper, Wyoming
2004 Arctic Fox 860 on a stock '07 Silverado dually
2005 BMW R1200GS and miscellaneous horses
2004 Winnebago Adventurer 35U
1990 Jeep YJ toad
Wrasle Castle
antioch ca
Posted: 05/13/09 10:12am Link  |  Quote  |  Print  |  Notify Moderator
I like the Idea of a built in and I will check into the EV 4010. It might be too large but I'll check it out when I get th TC home tomorrow. There is an odd dead space between the Battery box and the Genset compartment in the TC. I think that area might allow for the larger genset. I was thinking of useing it for more batteries but it might be able to be modified for both.
I have a generator for other uses but they are way too big to be packing around.
2009 F450 Lariat..mine
2008 Okanagan 117DBL..the DWs
Torklifts/Fastguns
Custom built 5x10 tandem axel quad trailer.
09 Honda TRX420AT the DWs
04 Honda Foreman Rubicon w/GPS...mine
95 Triumph 191 w/150 Yamaha and lots of goodies
1987 Suzuki Samurai
kcabpilot
CA
Posted: 05/13/09 11:19am Link  |  Quote  |  Print  |  Notify Moderator
When I installed the Onan in our Lance I decided to go with a gas fueled model KV2800. That meant a bit of extra work initially as I had to locate and install a fuel tank as well (the generator itself was a perfect drop-in fit as it's identical to the LP fueled model) There was an empty space in front of our generator compartment too and I found an Onan fuel tank on eBay that just happened to fit perfectly in that spot. The tank is about 8 gallons - enough to run the generator at full load for about 20 hours and can easily be refilled right at the gas pump whereas getting propane tanks refilled can sometimes be a hassle. An additional benefit is that with 60 lbs of propane I can get through two seasons before I need to service them!
Anyway, I'm in Antioch too so if you'd like to see/hear the Onan I'd be happy to give you a demo - just PM me.
1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches"
We also have a 'truck' that FLYS
Our recent camping trips
2manytoyz
Central FL
Posted: 05/13/09 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Here's the testing I've done with the Yamaha EF2400iS: Link.
It's the smallest, quiet series generator, capable of reliably running a 13,500 BTU A/C unit. You can do the same job with 2 Honda 2KW generators, but costs twice as much.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
http://www.2manytoyz.com/
Greg B
Minnesota
Posted: 05/13/09 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Another option if your still considering a portable generator is to get a high efficient A/C unit. Ours only draws 10 amps IIRC. A single 2000 Honda runs it with power to spare. Its a lot cheaper than buying 2 generators and a parallel kit. Also much easier than lugging 2 gensets around.
04 Dodge 1 ton dually, Cummins, auto, quad cab, 4x4, SLT, Sport, Reese Titan V
04 Lance 1161, TV/DVD, high efficiency A/C, Honda EU2000
Mooney
Santa Barbara, Ca
Good Sam RV Club
Posted: 05/13/09 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Im still running my 13,500 with one Honda 2000 . . . the true smallest and quietest that runs the PS series Coleman A/C.
 > generator ?
