RV.Net Open Roads Forum: Truck Campers: Replacing vinyl flooring
 > Replacing vinyl flooring
Truck Campers Related Tips
w2bpi1
Williamson, NY
Posted: 05/25/09 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
I had to remove the old vinyl flooring. Now the subfloor is very sticky! How do I remove the old cement? Thanks George
2000 Dodge 2500 5.9 diesel
2002 Lance 915
1997 Jayco 263RKS Fiver
Beddows
Abbotsford, Canada
Posted: 05/26/09 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Lay right over top, I did this with my old camper, worked great.
Photomike
Southern Alberta
Posted: 05/26/09 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
I laid mine over the old glue, just make sure that it is smooth or any bumps will show/wear through.
Don't forget to put your heating elements in first so you can have a heated floor
2002 GMC 2500HD 4x4 4 Door
1992 Northern Lite 9'- 6" Camper
Beddows
Abbotsford, Canada
Posted: 05/27/09 12:48am Link  |  Quote  |  Print  |  Notify Moderator
Missed the part about the glue. I laid mine right over top of the old vinyl.
joerg68
Ueberherrn, Germany
Posted: 05/27/09 01:51am Link  |  Quote  |  Print  |  Notify Moderator
I used one of these to remove the sticky cardboard
I could not get the sticky stuff off. Since its right on the OSB, there really is no way to use any solvents to strip it off, either. But I got it to be fairly smooth. Then, you need to be extra careful cleaning and removing all particles because they will stick to the floorboard.
Took about 2 hours just scraping off the cardboard backing of the old floor which was still stuck to the OSB. If I had to do it again, I would lay the new floor on top of the old one and put some cardboard or whatever in the place where the old floor absolutely had to be removed. So all would be level again.
The replacement floor probably has a thicker backing which helps with the uneven surface that remains.
Best regards
Joerg
"Pickups are very handy cars. One step on the brakes, and everything you need is right behind you!"
w2bpi1
Williamson, NY
Posted: 05/28/09 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
I had to repair some floor damage and had to remove some of the vinyl. Old vinyl was in poor condition so I could not put it back in. So after removing all the vinyl I scrapped up the paper backing and as much glue as possible. Then I put down a sheet of 1/4" luan under layment. Put vinyl on that. No glue. It lays very flat without the glue. Added few more pounds to the camper but looks great. Such fun George
VE7EDL
Port Coquitlam,British Columbia,Canada
Posted: 05/28/09 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have seen a few of the newer campers use Laminate Flooring, looks nice, not sure about the durablity.
2004 GMC 3500 D/A LLY Duramax Crew cab LB
2004 Corsair 10'4" Slide
Torklift tie downs with superhitch
Firestone Airbags
w2bpi1
Williamson, NY
Posted: 05/28/09 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
We were considering that. But if it gets damp underneath it becomes a mess. Pergo and others advise not using there products in situations where there is a lot of moister. We have a lot of Pergo in our home. great stuff for sure.
Blueboat
Arizona, Mesa
Posted: 05/28/09 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Here you go, citrus adhesive remover
http://www.citrusdepot.net/info_mastic.html?gclid=CMLb7cyO4JoCFShRagoduzuvBg
http://www.ellsworth.com/display/productdetail.html?productid=1784
http://www.specialtytapesupply.com/Polyken-41-Citrus-Cleaner---Adhesive-Remover.html
I have used this in homes and commercial buildings great stuff; we got ours at Home Depot. You could put a fan or small electric heater to dry out the camper floor after removing the sticky.
Mike
2009 Dodge Cummins 3500 LB 4X4 SRW
2010 811 Arctic Fox on order.
BCSierra
Victoria BC
Posted: 06/01/09 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
I put laminate in over the old lino and just sealed the perimeter with silicone seal before putting the trim on. We were camping in April when it rained about half the time and had no problems. If it ever did have issues, it's easy to replace. The stuff from Costco has the foam attached to the back which makes it super easy to lay down.
2001 GMC Sierra 2500 SLE Short Box 4 door Extra Cab
6.0 Vortec, 4L80E Auto Trans, 3.73 rear. 4X4. Timbrens, Rancho 9000's. Hidden Hitch front and Happijac rear tie downs. 1985 Frontier Camper.
Member/Editor of Victoria Motorcycle Club and ASHRAE
