mpfireman
Cook County Il
Us backyard grillers have a problem with the store bought pre filled propane tanks. REASON In 2008 when the oil prices spiked, these 20# pre filled tanks were being short filled some 2#LBS to avoid the rising price of propane. So even today with propane prices down almost 50% from last years high, this practice is still in place. I guess that we did not notice the difference, thus the continued practice.
So to get a full fill in your 20# tank, you might have to visit a retail propane dealer, and avoid these pre filled tanks.
Chicago Sun Times 5/24/09
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
luck would have it
Dimondale (Lansing), MI
We keep the same tank and have it filled at the flying J, but thanks for the heads up. I was unaware of that. Seems like if they are selling you 20lbs of propane, there should be 20lbs in there.
Dave
2005 Silverado 2500HD Crew Cab, 6.0L, 4:10 Gears, 2WD
Prodigy Brake Controller • Husky WD Hitch • Dual Cam Sway Control
2007 27' Salem BHBS (Bunk Slide/Super Slide)
skipnchar
Topeka Kansas USA
I've never seen ANY exchange program that didn't take a "big bite' for themselves out of what they charge for propane compared to having your own tank filled.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
TubaPete
Comstock Park, MI
skipnchar wrote: I've never seen ANY exchange program that didn't take a "big bite' for themselves out of what they charge for propane compared to having your own tank filled.
So true. Exchange programs are selling convenience, not propane. Works great for a back yard grill, not so well if you use a lot of propane.
Tuba Pete
david_42
Oregon
You pay a huge amount for the convenience of exchanging a tank. Being shorted a few pounds is minor.
John & Christine
Milford
Propane tanks should only be filled to 80% of its capacity to allow for expansion. That means a 20# tank should max out at 16#'s of gas. An internal float in the OPD operates and does not allow more propane to be transferred.
1*
BB_TX
McKinney, Texas
Article in local paper just 2 days ago. The 20# tanks you exchange at Walmart, Home Depot, etc. that used to contain 17# are now down to 15#. Check the small print on the bottom of the label.
Ozimo
NU/Cape Verde Isl
John & Christine wrote: Propane tanks should only be filled to 80% of its capacity to allow for expansion. That means a 20# tank should max out at 16#'s of gas. An internal float in the OPD operates and does not allow more propane to be transferred.
Then they shouldn't call it a 20# tank - truth in advertising! My 20# tank has 4.2gals of LP in it. I never bought by the pound.
Ace!
So Oregon
Ditto the 80% full comment above. They are not to be filled to 80%, else they are considered overfilled. Max for a 20 would be filled to 16.
TraciK
Louisiana
Interesting! Since we have moved we take our tank and get it filled. Thank goodness.
