RV.Net Open Roads Forum: Truck Campers: Will it be that easy? Final Update
 > Will it be that easy? Final Update
Truck Campers Related Tips
jwolff
Pasco, Washington
Posted: 07/01/09 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
On my '01 F350 they were super easy (with the use of their bolt fishing tool), even with the gas tank in the way on the drivers side. Backs just bolted straight to Super Hitch and fronts bolted straight to frame.
But, my '95 F350 was a major pain. Took most of a day drilling holes into the frame. Two on the front per side if I remember right and TEN in the rear for the Super Hitch. If you do end up drilling get a rental magnetic drill press and mount it upside down under the truck to drill the holes. I also used a jack to help hold the drill press so I could put even more pressure on the bit to dig faster.
I believe something as new as the OP will be "no drill" but for sturgeon phish you could be in for a long day.
I do my fastguns by feel. I used to do them pretty tight but got nervous about damaging the camper so have backed off some. As for an actual torque for how tight, who knows, it is all by feel for me. I believe the fastguns have heavy springs inside of them so you shouldn't in theory be able to over tighten because the spring would compress. Not sure on that though.
John
John
2001 Ford F350 dually, crew, 4x4, 7.3
2007 Arctic Fox 990
1995 Champion Bass Boat
wnjj
Cornelius, Oregon
Posted: 07/01/09 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
gm412 wrote:
sprink699 wrote:
I installed mine in about an hour.....well 2 hours...with help from my dog and my 5yr old. Painless and easy, you'll love the Fastguns. Just don't tighten them too much.
How tight do you do your fastguns?
I pull the handle until all the slack is out and it bumps into resistance and look through the padlock hole. It should be about 1/2 blocked at that point.
Beddows
Abbotsford, Canada
Posted: 07/01/09 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I believe they are supposed to stretch 1/4 inch. You will find they loosen on one side or another due to the camper shifting slightly.
sirdrakejr
Las Vegas, Nevada
Good Sam RV Club
Posted: 07/01/09 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Well, talk about timing!! I was going to post the same question here. I am ready to order my TC and since it is being trucked from Indiana, I am going to have to do my own as well. I have a Dodge 1T SRW long bed. Anyone have experience with that?
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
Jumbo Jet
Ozark Mountains, Arkansas
Good Sam RV Club
Posted: 07/01/09 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Frank
Been there, done that to two 2004's and a 2008.
TL supplies a wire to fish the bolts into the frame on these model trucks.
Back mounts require a little loosening of some bolts and alignment of bolt holes with the bumper mounting bolts.
2008 Dodge Ram 3500 Cummins Turbo Diesel - 1999 Lance 1030 - Torklift Tiedowns, Stableloads, Derringers, Pigtail - Hellwig Anti-Sway Bar - Rickson 19.5" Aluminum wheels - Michelin XRV tires
bb_94401
San Mateo, California
Posted: 07/01/09 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Frank
Install with the "no drill" tie downs was easy for the rear.
It depends on the fronts. Fairly straight forward with no running boards or nerf bars. I have "wheel to wheel" nerf bars on my dually that they had to be installed around these. Took a while to adjust them, choice of bolt holes to get the first one set. Other side was a breeze.
Make sure to install the 1/4" spring clips, that hold the insert in, on the top of the tie down receiver, not the bottom (had one scrap off while boondocking and lost the bent insert that goes into the receiver).
If you have not ordered the Fastguns yet, you might consider the polished stainless steel ones. They cost the same as the painted ones and you only have to wax them to remove small rusted areas to maintain them vs. dealing with pited paint and rust discolored paint.
Fastgun tension according to the manual:
"...pull lever handle down until you begin to feel spring tension when the hole for the snap pin is about 1/2 blocked."
"The external round O-ring is only used as a guage to set your spring tension. Adjust the O-ring up against the bottom of the tube before locking the lever down. Locking lever down should result in O-ring spaced approximately 1/4" below the body of the turnbuckle."
Mine usually sit between 1/4" and 3/8". Out of habit I check the O-ring position whenever I stop.
San Mateo, CA
'05 Ram 3500, 4x4, DRW, LB, 6spd man, CTD, PRXB exhaust brake
'01 Corsair 10'8" - 4,200 lbs., Xantrex XADC 80A, Link 20, 4-Lifeline GPL-4CT, PowerGate Isolater, 2 AWG wire, PI 30A EMS, 2 Honda EU2000i, parallel kit, ext. duration tank.
wp6529
TX
Posted: 07/01/09 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
"Make sure to install the 1/4" spring clips, that hold the insert in, on the top of the tie down receiver, not the bottom (had one scrap off while boondocking and lost the bent insert that goes into the receiver)."
This is a good point, and something that I considered when I fabricated my mounts. Beyond putting the clip on top where it is protected, I made my chain / turnbuckle assemblies with no hooks, all connections are with screw links, so nothing can bounce loose.
Sturgeon-Phish
Ohio
Posted: 07/02/09 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Well I installed my Torklifts today. It was fairly simple with well written instructions. Very well made also. Started the air bags, got one side done and will finish them Friday.
Jim
2000 Citation Supreme 10'6"; 1996 GMC 2500 6.5 diesel, Kennedy Exhaust, Heath remote PMD, 97 Airbox, Amsoil Fluids, Michelin LTX's Rancho 5000, Tork Lifts, Extra leaf in rear, Firestone Air Bags, Boost, EGT, Trans Temp pillar pod
southerlytide2
Canton NC west of asheville
Good Sam RV Club
Posted: 07/02/09 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Eric, Bob here, you know you have one of the best persons to get advice from and you even camped with him call mike xtrv He'll help you gosh knows he's install a few of them. Heading off hopefully next week for a weekday fishing trip at carolina beach.
sirdrakejr
Las Vegas, Nevada
Good Sam RV Club
Posted: 07/02/09 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Oh oh. My truck has full length aluminum running boards. I can see that may be a problem. Thank you.
Frank
