RV.Net Open Roads Forum: Tech Issues: LP gas detectors
 > LP gas detectors
brianseay
Bridgeport, Al USA
Posted: 07/01/09 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I have a 97 Damon Challenger motorhome and my LP gas detector keeps beeping every 4-5 minutes. two or three beeps each time. The green power light does not stay on. It will if you push the test button but then it will go back off. I have had the motorhome since 2004 and have never had any problems with them before. The one in the bedroom does not seem to work either. How long do these detectors last? I do not smell any gas and we have been out in it since sunday. It just started doing this last night (the one in the livingroom). I had not noticed the one in the bedroom. This is the second time we have been out this year, everything else checked out just fine on the first trip. Any help would greatly be appreciated.
Brian & Neena Seay
1st time rv owners and loving it ( so far)
1997 32' Damon Challenger
2000 Mustang GT / 2005 Harley Davidson Ultra Classic
ROLL TIDE ROLL.......
SCRC #217001 & #217002
heavyputer
Ontario, Canada
Posted: 07/01/09 08:59am Link  |  Quote  |  Print  |  Notify Moderator
You describe the symtoms of a low or dead battery. The LP detector will act just like that if you have a vey low battery. JMHO
Heavyputer, 1 DW,
2008 F150 4X4, 5.4l, 24 valve
2008 Dutch Star, 400 Cummins, 6 Sp Allison
Hurricaner
Hurricane Utah
Posted: 07/01/09 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Gas detectors are good 5 to 10 years. You can kill power to the unit and reset it but it should be replaced.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Clay L
Sioux Falls, South Dakota
Good Sam RV Club
Posted: 07/01/09 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Sam is correct.
Both my carbon monoxide detector and LP detector died a couple of months ago.
The CO detector started beeping every 30 seconds and the LP detector just started beeping all the time. The Co detector had an "replace after" date on the side and it died about a month before the date.
The manual for the LP detector said to replace 5 years after a date sticker in the manual. It died about six months or so after the date.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Wherever I happen to park
Posted: 07/01/09 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Low or dead battery is one cause..... Another is "General fault, internal"
First check your batteries, if they are full up press and hold the RESET/TEST switch till it alarms,
That should reset it
californiatraveler
Goleta,Ca 93117
Good Sam RV Club
Posted: 07/03/09 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of new detectors would be a good and not very expensive investment , for your safety.
NanciL
Bakersville, NC, USA
Posted: 07/04/09 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Mine did it when the main TT battery went low.
JackL
Jack & Nanci
revump
Las Vegas
Good Sam RV Club
Posted: 07/04/09 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
Mine did the same thing. I had to replace it. That was much easier than trying to figure it out and discovering that it needed to be replaced anyway.
Bob
 > LP gas detectors
