dnrv
Northern California
Anyone have DC outlet(s) installed in coach? If so, do you find useful?
edit to add: are the outlet(s) off house or chassis battery?
edited 07/03/09 11:26am by dnrv *
dnrv
lostmarbles
Sacramento, CA., USA
I have (2) 12 volts cig lighter types that I use an inverter for a laptop and a dvd player with the same inverter.
We have all sort of links and Tech informations on our group wesite below. A lot of them from different forums including here, over the years. Feel free to browse and use.
CLICK HERE FOR CENTRAL/NORTHERN CAL RV'ER/BOAT GROUP.
Happy Camping!
Roadpilot
Lakes Region of New Hampshire
We use ours for a backup GPS.
2007 Newmar Essex 45'
2006 Honda CR-V and 2005 Chevy Silverado 1500
2009 HD Electra Glide CVO Screaming Eagle - mine
2009 HD Street Glide - DW
Overbilt Lift on Essex and Rampage in Chevy
karlstream
Gig Harbor, WA,USA
I have 5 DC outlets scattered throughout the coach powered off the house battery. A couple are for the TV. One is on a 30 amp circuit so I can run 110 volt power tools off an inverter. Another is in an outside compartment for topping up the air shocks with a 12 volt compressor. And finally, one is mounted outside on the curb side so I can plug in a fluorescent light for reading outside at night. We use all of them quite a bit.
karl
bananadanna
Cambridge, MA
I put four duplex 12v fixtures in my DIY. One always powers the Engel fridge. The others see use here and there as phone chargers et al. I have provided 12v power to others on occasion.
You do get about 10% more efficiency if you don't run the power through an inverter. Would not matter for most people but my dc fridge is my major watt eater.
Many fixtures are rated for just a few amps. Mine are came from West Marine and can handle more watts than the basic ones.
Dan
02 Freightliner Sprinter 2500 long tall home brew conversion
Johno02
Lexington, TN USA
Good Sam RV Club
I have a 12v outlet mounted beside the bed. I use it to power a CPAP machine. Only thing is that if AC goes off during, CPAP does not, and doesn't wake me up.
Noel and Betty Johnson
'99 Hurricane 2007 HHR 1 wife, 2 1/2 dogs
booster
Minnesota
We will be adding a 12v "charging station" to our 07 190P as soon as we get our removeable armoir. I will tap into the fuse box that is right above the armoir and make holders for our rechargeables on top of the armoir.
