RV.Net Open Roads Forum: Tech Issues: Outdoor stove gas hookup help
 > Outdoor stove gas hookup help
Tech Issues Related Tips
Mr.Usa
42.754616,-87.807873
Posted: 07/03/09 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have the outdoor grill on my 23b with the quick connects but would like to also use my coleman stove out there. Does anyone know where to get a hose that will connect camper (1/4 male quick connect) on one end and 1 lb. throw away bottle on the other end?. I suppose I could chop up my extension hose and have someone crimp on a 1/4 fitting but I do not know who in town would do that.
08 Jayco 23B
02 Sequoia SR5 I-Force V8
Equalizer Hitch
The wife, Mrs. Usa
Our son AJ
Norman & his lil Buddy
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 07/03/09 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Camping World has what you want. I think any RV store can get the parts for you. Possible Lowes or Home Depot will have the necessary pieces to make one.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
red31
Bryan
Posted: 07/03/09 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Coleman 2 burner stove is regulated to 15 psi, you quick connect is ~0.4 psi.
The Coleman will not operate on 'low pressure' it is a 'high pressure' appliance. The 'container pressure' is regulated to high pressure (15 psi).
The hose is available but will not work! the 100476
javaseuf
California's Gold Coast
Posted: 07/03/09 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
This is correct.
Steve
2007 Springdale 291RKL
2009 F150, 5.4 ltr.
1986 Palomino Hard-Side PUP
"Nobody knows how we got to the top of the hill, but since we're on our way down, we might as well enjoy the ride". ("The Secret Of Life", James Taylor).
jauguston
Bellingham, WA
Posted: 07/03/09 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
To get high pressure propane you need to tap in between your tank valve and the regulator. Mr Heater and others make a kit to do that.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Mr.Usa
Posted: 07/03/09 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
So the connection at the trailer is only 4psi? Is the grill less than 4psi because it has its own regulator?
Hurricaner
Hurricane Utah
Posted: 07/03/09 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
.4 PSI not 4 PSI. The Coleman wants a 50 plus pound supply direct from the tank then regulates it down. Get a extend a flow for your propane tanks.http://www.pplmotorhomes.com/parts/lp-gas/propane-tank-adapter.htm
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Ron3rd
Upland, CA USA
Posted: 07/03/09 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Sam
You beat me to it. I use the Extendaflow kit on my Weber Q.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
C Schomer
Buckeye, Az.
Posted: 07/03/09 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
My Olympia rv grill also needs >15psi to the grill reg or it won't get to full orifice pressure (~15")for highfire. My old marshall tank regs are two piece (rather than the integral casting) and I get ~17psi after the first stage so I put a tee/valve/25' hose there for the rv grill. It's a cleaner looking plumbing job that the extend-a-hose thing, less $$$ and the rv grill is always using gas from the in-service tank. Craig
Mr.Usa
Posted: 07/03/09 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Can I just move that line before the regulator @ the main tanks since the grill already has a .5 lb regulator on it? Be an easier plumb job...lol
