tkey144
HOME
Good Sam RV Club
I have a 350 ISC Cummings that started missing and then shut down on me. The repair facility said the lift pump was fouled up with algea from the fuel tank.
Has anyone else had this problem and any recommendations for eliminating this problem?
marvmarcy
Polson, MT, USA
Good Sam RV Club
If you've accumulated enough black gunk in the fuel to foul the lift pump, you probably will have to drain and clean the tank and flush the fuel lines. You must have been going through fuel filters like crazy. Fortunately, the filter should prevent the gunk from messing up the injector pump and injectors.
Since you didn't mention the fuel filter being plugged up, I would inquire further of the mechanic to be sure what is really going on. Have you used bio fuel? That has solvents that break loose sludge in the fuel system, but it would also show up in plugged fuel filters.
Can you get more info on this?
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK (20K GVWR, tandem duals)
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
pulsar
Lewisville, NC
Good Sam RV Club
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Deen
Vancouver, WA
Good Sam RV Club
You might need the fuel "scrubbed" (filtered) any marina that's set up to work on diesels knows what that is. Basically they run the fuel through a filter and return it to the tank without the algae.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor and Recruiter
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
52nd yr of RV'ing
BIKERK9
Santa Cruz, CA
Good Sam RV Club
With operating diesels for over 20 years on land and sea, I have never had that problem. Besides having quality filters I always add diesel fuel conditioner. If your not using it, you should. Also I never leave my tanks less than a quarter full as that invites condensation.
DoggyDaddy
2008 Damon Outlaw 37', WH-24, 8.1 GMC
Class A Toy Hauler
DoggyDaddy CommunityProfile
msjdbman
SW Michigan
Man, sorry to hear of your troubles. I`ve been thru this myself with 2 pieces of heavy equipment and it ain`t no fun. When the painstaking and costly job of getting the entire fuel system cleaned out is done, add fuel conditioners as recommended. But make sure those conditioners contain an algeacide. Good luck, and make sure you bring the vaseline along cause it`s gonna hurt.
2008 Duramax/Allison LT2 Crew cab Standard Box. Hellwig Air Assist.
1996 Terry 27 5J
wolfe10
Your signature does not show where you live. If in an area with diesel powered boats, look up FUEL POLISHER and have them come out. What they do is bring a separate fuel pump and huge filter system and recirculate the fuel until clean.
Certainly, the tank can also be drained, cleaned and refilled.
Also add a diesel BIOCIDE available at any marine store. Just follow directions on label.
And always store diesel tanks FULL to reduce condensation that can lead to algae/bacteria growth.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Dave H M
IL
Not being in the know I wonder how algae can get thru the system/filters and then clog up something like the pressures that are present in an injection system?
Ajones42
North Texas
tkey144 wrote: I have a 350 ISC Cummings that started missing and then shut down on me. The repair facility said the lift pump was fouled up with algea from the fuel tank.
Once you get the fuel system cleaned out, a few maintenance procedures practiced consistently will keep the problem from reoccurring.
1. Clean fuel from a high volume jobber.
2. Fuel tank always near full when parked to prevent condensation.
3. Fuel/water separator drained according to manufacturer specs. Mine says whenever the tank is filled, the separator is to be drained.
4. Use of quality filters changed as recommended OR semi-annually.
5. The use of a quality diesel fuel conditioner that contains a biocide.
More here....
The Care and Feeding of Older Diesel Engines
Fulltiming in a 1993 Dolphin 32D
North Dallas, TX
My Old RV
