Contemplating Getting a Jeep or Samurai and hauling it in My Toyhauler.
Tell me if these numbers sound right?
Truck 06 F250 Curb weight ...............................7,302 I weighed it at the recycle yard.....
Jeep Curb weight................................................3,000 ( as per internet )
Samurai Curb Weight .........................................2,000 ( as per internet )
Trailer UVW .......................................................8,890 ( as per brochure from internet )Unloaded Vehicle Weight UVW ???
Gross Combined Weight with Jeep.....................19,192
GCWR ..............................................................23,000 Gross Combined Weight Rating ??????
Which should leave me ..................................... 3,808 Lbs for other stuff right???
Trailer GVWR....................................................14,110
That gives me ....................................................2,220 under trailer Max
Trailer GAWR Gross AXLE?? Weight Rating is....12,000 Does this mean single or for both??
This would put me just under max if it is for both axles.....
G rated tires x 4 =??????
06 F250 4dr short bed 6.0 PSD with camper package.
05 or 06 Rage'n 5er 30' Falcon
edited 07/27/09 05:13pm by Mike Mike Motorbike *
Everybody going faster than me is a "Maniac".
Everybody going slower than me is a "Idiot".
Don't they know I'M going the right speed.....LOL
How are the Jeep or Samurai equipped? One thing to keep in mind, nothing is the same as the brochure. It's like menu pictures. the food never looks the same right? So everything you add to the trailer beyond the bare minimum is added weight. More batteries, inverter, spare tire, fuel station, gel coat ice maker etc... all were considered add-on's to my trailer.
You did the right thing by taking the truck to be weighed.
FYI my Jeep is now over 4000lbs.
05 Chevy 3500 LT Crew Cab Dually,
06 WW SLC3905 Kenwood 6X9 speakers
03 Jeep Wrangler 4.5" Rubicon Express coils 1" body lift, 35" tires, 9000 lb winch, rock jock dana 60/detroit/4.88 rear, Dana 30/Detroit/4.88 front
07 Raptor 700R
07 Kymco 90 (X3)
12K for both axles on the Ragen FA3005. Is it a Gelcoat or tin sidewall? The Sammy may work but definitely not the jeep with stock axles and tires. Are you going to travel with a full water tank and fuel tank(s). With a full water tank and fuel tank(s) you wont have enough capacity left... do the calc's -this calculator is very conservative.....
My FA3005 with 3 dirt bikes loaded cross-ways in the back only has +/- 500# of unutilized payload on the 2 trailer axles with a full water tank, full 40 gallon fuel tank and gear/food/beer for three for a week trip. Just went across the scale about 2 weeks ago going out of town.....
GAW: Gross Axle Weight
Gross Axle Weight (GAW) is the actual weight placed on a single axle. Assuming a well-balanced vehicle, the GAW is then evenly distributed to all tires on that axle.
In addition to the axle weight rating, the GAW must be within the tire weight ratings as well. To determine the amount of weight placed on each tire, divide the GAW by the number of tires on the axle.
You may see the more specific RGAW, when referring to the rear axle, or FGAW, when referring to the front axle.
GAWR: Gross Axle Weight Rating
Gross Axle Weight Rating (GAWR) is the maximum number that the GAW of a single axle should never exceed. You may see the more specific RGAWR, when referring to the rear axle, or FGAWR, when referring to the front axle.
12,000 lbs. on trailer axles
trailer UVW is ............................8,890
Jeep .........................................3,000 ish
Sami .........................................2,000 ish
Chevy Tracker ..........................2,200 ish
Trailer with aTracker =11,090 leaves 910 for gear.
50 gal water X 8 lbs. = 400
two bikes ........ =500
And I'm at max.............?
What about all the guys I hear here that Haul Jeeps ? Are there trailers rated higher?
I would say you need to weigh your Rage'n first. My 2008 FA 3405 (4' longer) is listed at 8,860 Lbs. in the brochure? I weighed it on the way home from the dealer empty, NO water, NO Batteries, 8 Gallons of gas and a few gallons of propane and it weighed 10,500 Lbs. (8,100 on the axles and 2,400 pin weight) True weights will change everything..
