RV.Net Open Roads Forum: Around the Campfire: Figuring grade of a hill
 > Figuring grade of a hill
Around the Campfire Related Tips
ventrman
Erin, TN
Posted: 07/30/09 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
When I took Police Science in college, our text book described a method to figure out the grade of a hill using a level and a tape measure.
I have a certain hill that I need to figure the grade of.
Can someone here help?
God Bless!
Matthew_B
The boonies near Dallas, Oregon
Posted: 07/30/09 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
The percent grade is the rise divided by the run times 100.
Place a level with one end on the ground and make it level. Now measure how far the other end of the level is off the ground. Divide that number by the length of the level and multiply by 100 to get the percent grade.
ventrman
Erin, TN
Posted: 07/30/09 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick reply.
msmith1199
Central, CA
Posted: 07/30/09 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds correct. Basically a hill that is at a 45 degree angle would be a 100% grade. At 45 degrees every 100 feet you travel across a level plane you would rise 100 feet. So using Matt's formula that is 100 divided by 100 which is 1 multiplied times 100 which is 100% of grade.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
dave54
CA.
Posted: 07/30/09 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
If you know the degree angle of the grade (many clinometers show degrees, not %), take the tangent of the angle for % slope.
Log off and go camping!
sirdrakejr
Las Vegas, Nevada
Good Sam RV Club
Posted: 07/30/09 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you took a traffic school you should have gotten a little template that has an angle figure on it. It swings from a pencil along your clipboard. You look along the edge of the clipboard and then hold the template against the clipboard. You can see the angle displayed when done right. Boy, it has been a long time since I neded to do that !
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
ventrman
Erin, TN
Posted: 07/30/09 11:57pm Link  |  Quote  |  Print  |  Notify Moderator
Frank
I had one when I was in college, but that was back in the 70s.
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 07/31/09 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Shortcuts, THAT'S what it's all about!
This little SmartTool will tell you anything you want to know, % grade, rise/run, or angle:
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
