RV.Net Open Roads Forum: Truck Campers: Cargo Carrier Recommendations
 > Cargo Carrier Recommendations
Truck Campers Related Tips
woodhog
NS
Posted: 09/09/09 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking for a well built cargo carrier that installs on the trucks receiver hitch so I can put the generator and a few other items in it.
I dont want to put the generator in the camper due to gas smell.
I would like it to be very well built, not too heavy and not wobble and sway around when it is on the road.
Would it be better to have one in the front or the back?
Thanks
2004.5 Dodge 4x4 SRW Diesel 3750 Lb tires.
2006 8.5 Northstar Arrow
clinthia
Flathead County, Montana
Posted: 09/09/09 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Here's one from Harbor Freight and its on sale
Clint
2007.5 Dodge 3500 4X4 with 6.7 liter Cummins
2004 EC 950 w/ slideout
2-6 volt Costco batteries
Yamaha EF1000ISC
Kyocera solar panel
Torkjac/Happilift tiedowns
Torklift Fastgun Derringers
Timbrens
Inexpensive bump stops
and Madeline the Schnauzer (aka LBD)
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Good Sam RV Club
Posted: 09/09/09 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have one of these from Cabelas.
It raises the carrier up to give better ground clearance and I mount it to my front receiver hitch.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
Dewclaw
Oregon
Posted: 09/09/09 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
Good idea, woodhog. In fact, it's a great idea since it's the same as mine.
The NL comes straight off the bed with no dropped portion and that gives me room enough to put a carrier on the hitch that will carry the small generator. I'll want it to have an enclosed waterproof and dust proof box, though, to protect the generator. I'm off pavement a lot.
2008 Northern Lite 9-6 Q Classic SE
2007 GMC 2500HD
Raften
Northern Calfornia
Posted: 09/10/09 12:24am Link  |  Quote  |  Print  |  Notify Moderator
I have used the one from Harbor Freight for a few years now and it is doing the job well. It is rated for 500 pounds, but I never put that much in. I carry 25 gallons of fuel or just a gen set and some firewood. Carry it on the front as it gets in the way for ingress/egress in the back.
Steve_in_29
Good Sam RV Club
Posted: 09/10/09 12:28am Link  |  Quote  |  Print  |  Notify Moderator
Since you mention "off pavement" keep in mind that a hitch carrier mounted low under the rear of the TC will seriously cut into your departure angle.
southerlytide2
Canton NC west of asheville
Good Sam RV Club
Posted: 09/10/09 06:08am Link  |  Quote  |  Print  |  Notify Moderator
I have one of these modified but you can see it hold all sorts of stuff plus theres a winch behind it.
luv2skyski
Stockbridge, Georgia
Posted: 09/10/09 06:59am Link  |  Quote  |  Print  |  Notify Moderator
A two point mounting system will significantly reduce the "wobble and sway". Here's the solution I came up with. Got the idea from JoeOchiki. Dave.
2004 Northern Lite 10-2000RR, 1999 F250
luv2skyski.com
Northern Lite Owners
Truck Camper Enthusiasts Map
4 out of 3 people have trouble with fractions.
Dewclaw
Oregon
Posted: 09/10/09 07:33am Link  |  Quote  |  Print  |  Notify Moderator
True, but it should be little worse than the very nice steps that NL has mounted on the rear bumper. The steps make negotiating some places a team effort with someone watching the back since I can't see them. The proposed carrier will fit under the camper, but in front of the steps. It will only be easily accessible when unloaded, but that is all I need.
hard3
southern Illinois
Posted: 09/10/09 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I got mine from Walmart, $50 I then got out the drill and drilled a new hole for the hitch pin with it pushed all the way in , so it doesn't stick out from the receiver as far. 2 turn buckels to the underside of the bumper take out a lot of the sway and rattle.
