RV.Net Open Roads Forum: Got our camper home and have a couple questions
Open Roads Forum  >  Hybrid Travel Trailers
 > Got our camper home and have a couple questions
Hybrid Travel Trailers Related Tips
troy t
home
Posted: 09/29/09 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Just brought our new to us Travel Star 21SB home. It was a repo unit that we bought and had my dad pick up for us.
1st issue - no keys for the outside storage doors. How do i get keys?
2nd issue - the plastic housing or cover blew/fell off the AC unit as my dad was bringing it back from Indiana, any idea on how to get a replacement
3rd issue - Needs some caulk on roof near bathroom skylight and fan. What type should I use?
Thanks for all the help! I'm sure as I try all the functions, I'll have many more questions.
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 09/29/09 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Almost any RV supply can get you storage keys. The air conditioner covers are abailable there also. I recommend using Etremabond to seal the skylight and fan.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
ngreen
Neosho, MO
Posted: 09/29/09 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
All the keys are the same - yea your keys will unlock my storage doors unless I change the lock - which alot of people do
Contact any RV dealer that has a RV supply store - they will have the keys
Welcome to the great world of RVing
CREATO
Beautiful Harvey N.D.
Posted: 09/29/09 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Most rv dealers will have the keys for outside storage doors most units have the same keys might even ask a freind with a camper to try his and then have them cut at an rv store
you can buy the ac cover also from rv dealership will need model and sn of of ac to get right one
as far as caulk do you have a steel or rubber roof
I DON'T RENT OUT SPACE IN MY BRAIN
skipnchar
Topeka Kansas USA
Posted: 09/29/09 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Use DICOR on your roof to replace caulking with the same as the original.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
KingGlamis
Mesa, AZ
Posted: 09/29/09 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Check the front of the lock cylinders. Most have a number stamped in them. 751 is a common one. Then just go to an RV place that sells parts and ask for "751" keys (or whatever the number is).
If you don't know what make and model A/C unit you have you will need to provide them with the model number. You'll be able to get this by climbing on the roof and finding the ID tag on the A/C unit. Many have a similar tag on the underside but you may have to remove the ceiling assembly to see it.
The DICOR Lap Sealant is excellent stuff.
