RV.Net Open Roads Forum: Truck Campers: TC on a pontoon boat platform?
 > TC on a pontoon boat platform?
Truck Campers Related Tips
My Blue Heaven
Missouri
Posted: 10/07/09 10:33am Link  |  Quote  |  Print  |  Notify Moderator
First of all, this is more of a theoretical discussion at this point. It's not like I'm ready to tie one on.
As nice as some of the TC's are these days, if a guy could mount a TC on a flat pontoon platform, it might make a pretty nifty houseboat and you could get more use out of your TC.
I supposed the TC would have to be reversed and the chairs and controls on the boat moved to the front under the overhang with perhaps a (short) door under the overhang allowing access from that end.
Would the TC be too much of a load for the pontoons? Given the amazing capacity of my inflatable, I would suspect that a 20 to 30 foot pontoon (or a new tri toon) boat would have no problems hauling 4K pounds.
Has anyone heard of such a thing? Do one of you have such a thing in his back yard? If this is an original idea, remember you heard it here first and be sure to send me the royalty checks.
formerly avionguy
2001 F350 Lariat CC 4WD 7.3 PSD dually, chipped, 4" SS exhaust, 350 hp, Rancho 9000's, front receiver
2009 Arctic Fox 990S, storm windows, Cummins/Onan, FastGuns, Torklifts
kohldad
Goose Creek, SC
Posted: 10/07/09 10:45am Link  |  Quote  |  Print  |  Notify Moderator
It's not a new idea. But I have to ask, how is putting a 15' TC on a 30' pontoon going to allow you to get more use out of it? It may give you the ability to go on the water, but you will lose the ability to explore all of the back roads where the small size of the TC is it's biggest advantage. Besides this issue:
The pontoons would have to be larger than your normal party parge and definitely a tri-toon to carry the load.
What I have seen in the past that provided more use for on/off water was a pontoon with retractable toons. When loaded on a trailer, it was 8'6" wide and you had to walk through the cabin. After putting it in the water, you extended both pontoons about 2' each side giving a nice walkway around the cabin. Above the cabin was a nice viewing deck with a bimini top.
Or you could just go with one of the land yachts that can go into the water and travel about 8 knots. The videos of that thing were cool.
Photo Albums (Congaree NP added 12/09/09)
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd
2004 Lance 815
1982 CJ-8 Scrambler - going, going, anyone
Loving wife, two horse crazed teenage daughters, two horses, two cats
SHEEPDOG
SAN ANTONIO
Posted: 10/07/09 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I have thought about this over the years but I was thinking a noncabover TC like the Capri campers' "model 42" would work better because there is no cabover it is basically just a box. I think it only weighs about 7-800 pounds.
07.5' Dodge 3500 DRW 4x4 L/B Cummins
08 Arctic Fox 990
sleepy
Oak Ridge,Tennessee
Posted: 10/07/09 10:54am Link  |  Quote  |  Print  |  Notify Moderator
it would no longer be a truck camper!!!
it would be very limited for going anywhere except up and down a river or around a lake
fuel on the water is more expensive than on land
you still have to dump your tanks... you'd have to change them out to something coast guard approved... the fines for "spills" could be very high.
CG inspections might get hairy...
Silliest idea to hit RV.net this year... maybe for 10 years.
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans model 6150/AC/winter package
AirFoil, Trimetric, LED lights
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
Sportsman Matt
Blackstone, MA
Posted: 10/07/09 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Anything is possible, heck if a bunch of guys can put an old pickup truck cab and engine on a platform of barrels and set sail for mainland with a homemade drivetrain, then you could put a TC on a pontoon boat.
Just be prepared for problems when trying to make fast manuevers due to a very high COG
Life is short, Play harder.
2002 GMC Sierra 1500 Regular Cab Long Bed 4.3L V6 Automatic 2WD
1989 Sunline C-750 Slide In Truck Camper
7'6" Floor, 11'6" OAL
Fishing and Hunting New England and eventually the world
cruiserjs
Aurora, CO, USA/ Mesa AZ/ openroad
Good Sam RV Club
Posted: 10/07/09 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Sure - a few years ago, on Shushwap lake in BC we saw a large motor home that was driven onto, and tied down a larger flat top pontoon boat! The marina operator told us that the owner winter in the south somewhere and spent most of the summer on his "house boat" but did take it off occasioally for summer trips.
Such a deal!
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2009 GMC Sierra 2500HD, 2wd, short bed
wonderful lifetime traveling companion/spouse
silversand
Montreal
Posted: 10/07/09 10:59am Link  |  Quote  |  Print  |  Notify Moderator
....I remember seeing a Camel Trophy (or, similar) event where custom-made pontoons were used to propel Land Rovers (and other vehicles) across deep rivers...so, def. possible to have a pontoon boat made to seat a TC on I should think...
The name that comes to mind when wanting a custom inflatable/pontoon application is: Jack's Plastic Welding, in Aztec, New Mexico here-->
I've talked to them (in the past) about rugged custom inflatables for use in Central America. They work with CAD wire-frame designs before production, and they state, "We are looking for customers who have difficult engineering problems that may be solved with the use of products made with coated fabrics. The incredible strength, air and liquid holding capabilities of coated fabrics are often great alternatives to the use of heavier more permanent materials."
Good luck,
Silver-
Silver
My Blue Heaven
Missouri
Posted: 10/07/09 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Gee, Sleepy. Silliest idea in 10 years? Maybe you got a laugh out of it, then.
Jumbo Jet
Ozark Mountains, Arkansas
Good Sam RV Club
Posted: 10/07/09 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Is it a DUALLY pontoon? Otherwise you would be overloaded.
2008 Dodge Ram 3500 Cummins Turbo Diesel - 1999 Lance 1030 - Torklift Tiedowns, Stableloads, Derringers, Pigtail - Hellwig Anti-Sway Bar - Rickson 19.5" Aluminum wheels - Michelin XRV tires
Jay Pat
Round Rock, TX
Posted: 10/07/09 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Old idea.
Galvanized steel frame, Styrofoam blocks for floatation, lightweight concrete decking, outboard motor and travel trailer in the middle (Axles removed).
Low maintenence, high enjoyment!
You may be on to something......
Pat
Future home of future RV.....
