RV.Net Open Roads Forum: Tech Issues: Is an accumulator tank necessary
 > Is an accumulator tank necessary
Tech Issues Related Tips
exportman
Clovis, Ca
Good Sam RV Club
Posted: 10/09/09 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I am looking to buy a new Shur flo water pump. My old one is much too noisy. The whisper king model offered at Camping World looks to meet my needs. However, I'm wondering about accumulator tanks. Is it a necessary item with this pump or is it just nice to have?
Billyj571
Marysville,WA
Posted: 10/09/09 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Nice to have. Won't have to pump as often running that is.
crickeydog
Marietta, Ga.
Posted: 10/09/09 09:33am Link  |  Quote  |  Print  |  Notify Moderator
FWIW: I installed a "Whisper King" a couple of years ago and found although a bit more quiet, it cycled more often and it didn't seem to pump the same GPH as the previous pump I was replacing due to failure. IMHO: If I were intalling a "Whisker King" pump, I'd also install an accumulator tank as well.
Happy camping!!! See ya'll down the road!!!
USAF RETIRED
2006 GMC 3500 CC DRW D/A 4X4 SLT,PREDATOR,VOLANT CAI,FS2500 OIL FILTER'S
2004 HR PRESIDENTIAL 30 SCD.
CHEROKEE & CHEYENNE MINI DOXIE'S. WE'RE IN CHARGE!!
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE.
IT'S 5 O'CLOCK SOMEWHERE!!
exportman
Clovis, Ca
Good Sam RV Club
Posted: 10/09/09 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Further info to my post, in 2005, I was having some installation work done at the CW store in Rocklin, Ca. One of the items was a new pump. After it was installed, the pump wouldn't pump anything more than a trickle out the faucet. The installer said I needed an accumulator tank which he didn't have in stock. So, I told him to take out the newly purchased pump and put the old one back in. I've been living with an ever increasing noisy pump since then. Was this guy just mis-informed? Why wouldn't that new Shur-Flo pump work?
On edit, I am reading the posting above this one re the tank. Hmmm.
JUrban
Delaware
Posted: 10/09/09 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I put in a ShurFlo Smart Sensor and have been extremely pleased with it. The pump runs at variable speed depending on demand, and starts and stops soft, so the noise is way down. No pulsing when just using a trickle, but plenty of flow for big jobs. It was a bit larger than the old cheapy pump, but essentially a 15 minute swap out. I'd highly recommend you consider this one.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
exportman
Clovis, Ca
Good Sam RV Club
Posted: 10/09/09 10:04am Link  |  Quote  |  Print  |  Notify Moderator
John
the reviews on the CW site are mixed for the particular unit you recommend. Understanding you're having good luck with it, I'm wondering if you also have an accumulator tank in that big coach you drive.
FXSTOHIO
Ohio
Good Sam RV Club
Posted: 10/09/09 10:08am Link  |  Quote  |  Print  |  Notify Moderator
I put a Shur flo accumulator tank in this past spring and had to re plumb the pump to get it to fit in the space I had. I see very little difference and I wouldn’t do it again because I really see no benefit as of now.
2008 Pilgrim Lite 21LRB
2004 Chevy Silverado Extended Cab 4x4 5.3 Tow Pkg 3.73
Yamaha EF2400IS
OlderThanSand
Tollhouse, Ca
I just bought a accumulator tank but haven't installed it yet. I'm confident it will "smooth" the water flow coming out of the fixtures by providing consistent water pressure. They have an internal bladder and they claim, and it seems to me as well, that this will reduce "hammering". If none of this is true I'm only out $50 and a few minutes of my time installing it.
FYI in my research I found that they are not recommeded with some pumps and you need to make sure you get the tank with a precharge that matches your pump pressure. I've heard the variable pumps work well without a tank but are rather pricey imo.
2002 4x4 Super Duty PSD
2006 22' Carson Titan
2009 Polaris RZR
2007 Suzuki LTZ 400
2007 Honda TRX 250EX
1995 model dune crazed granddaughter
lookinin
Southern British Columbia
Posted: 10/09/09 10:15am Link  |  Quote  |  Print  |  Notify Moderator
It's a handy-dandy thing to have. Great burst of pressure at the kitchen faucet or shower head. Shut the tap off, wait for the pump to catchup and enjoy the pressure in a few minutes time. Less short-cycling of the pump and no nighttime rumbles when using the facilities in the "quiet hours."
Cheers,
Kevin
Dutch_12078
Great Sacandaga Lake, NY
Posted: 10/09/09 10:19am Link  |  Quote  |  Print  |  Notify Moderator
I installed the small ShurFlo accumulator tank in my old Class C and was reasonably happy with the performance. The pump ran less often, and there was no fast cycling at lower flow levels. When we bought the Class A, I installed a 2 gallon accumulator tank from Lowes and I like this setup even better. The pump runs much less frequently, although it does take a bit of getting used to the longer run times when it does kick in. When I installed this one, I included a shutoff valve so no anti-freeze would go into the tank when winterizing after the pipes were drained.
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
