RV.Net Open Roads Forum: Issue with Seneca A/C and defrost selector switch
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Issue with Seneca A/C and defrost selector switch
Class C Motorhomes Related Tips
Pigkisser
West Texas
Posted: 10/12/09 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have a problem with the selector switch for the A/C, vent, defroster, heater, etc on my 2007 Seneca. No matter which position the selector switch is in, it blows air from the windshield vent, heater vent and dash vents at the same time. I'm sure it is a vaccuum hose problem, but I was wondering if anyone has had this problem and how should I proceed with trouble shooting the problem?
2007 Jayco Seneca 33SS
2008 Jeep Wrangler 4 door 4X4 toad
Ready Brute/Ready Brake tow bar/brake combination
Igloo Ice Chest
sbishop
Eagle Rock, CA
Posted: 10/12/09 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
I was having problems with vacumm leaks in my rig and ended up removing the control panel and vacumm testing each line. There is probably an easy way but that is what I had to do. It may be that the vacumm line supplying vacumm to the controls is bad and your system is reverting to the default. A good AC shop can probably tell you pretty quick.
David Bishop
1990 Bounder 27D
Desert Diesel
Anaheim Hills, CA
Posted: 10/12/09 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
You might be having trouble with the HVAC control module since it's all electronic and sometimes just needs to be reset or reprogrammed at the dealer.
I would try disconnecting the chassis batteries for 10-15 minutes to reset the module. Then turn the key to the on position for 30 seconds before starting.
07 Jayco Seneca 34SS
20' Universal trailer
02 2500HD D/A CC/LB
ronfisherman
SE Michigan
Good Sam RV Club
Posted: 10/13/09 05:52am Link  |  Quote  |  Print  |  Notify Moderator
The Kodiak chassis MH's have a vacuum operated HVAC system. Here is a link to schematic of vacuum system. There is a vacuum pump someplace on the engine or passenger side frame rail.
To get at the controls you will need to remove the outer instrument panel bezel. Start pulling out on right side and work loose across dash.
A 2008 Kodiak should still be under warranty. Maybe a trip to the dealer is needed.
ronfisherman
SE Michigan
Good Sam RV Club
Posted: 10/14/09 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Got a chance to look for vacuum pump. On my 2004 it is located on passenger side of radiator assembly. Flipped the hood forward and found it and a small tank.
Rich Panganiban
Southern California, USA
Posted: 11/03/09 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Was the OP's issue resolved? What was the solution?
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
Pigkisser
West Texas
Posted: 11/04/09 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I've been out of town since shortly after the original post. I will be home this week-end and will hopefully have a chance to track down the problem. I did find Desert Diesel's response interesting, because the problem started after I had to jump start the truck due to weak batteries. We'll see. I appreciate all of the input and will advise when the problem is fixed.
BEVAR
Lake Worth, FL
Good Sam RV Club
Posted: 11/04/09 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious, but how did you jump start the coach?
Beave
Pigkisser
West Texas
Posted: 11/07/09 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
I utilized a 12 volt rechargable jump-start battery box connected to the positive lead in the access panel located under the hood on the passenger side. I grounded to the frame.
BEVAR
Lake Worth, FL
Good Sam RV Club
Posted: 11/07/09 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Did you know you can jump yourself with the generator? Start up the genny, sit behind the wheel and press and hold the white "connect" button next to the steering wheel and turn the key. The Duramax should start right up!
Beave
