ajhartle
Clear Spring Md.
I have had trailers before but none had the battery cutoff switch on them. What exactly is it for .Mine is on the out position is that where it should be? Does it have something to do with the truck charging system?
skipnchar
Topeka Kansas USA
It just saves you from taking the negative lead off of the battery while the trailer is in storage. without one or the other the batteries will be drained over time.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Vulcanmars
Naples, FL
Good Sam RV Club
Mine kills all the 12v stuff like radio/smoke/CO detector. It will also stop the batteries from charging on shore power.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Y-Guy
Tri-Cities, WA
Good Sam RV Club
Sometimes there are two cut offs, one to cut power to the fuel station the other kills all power. As Vulcanmars said by killing the power to the radio/C0 detector you kill the parasitic draw that can slowly drain a battery over a couple of weeks.
Winnebago Sightseer 35J | Custom ATV Trailer | Polaris Sportsmans & Honda Recons
Broccoli1
Los Angeles
ajhartle wrote: .Mine is on the out position is that where it should be?
depends on what ya want it to do
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rhino 660- 1980 Cobalt 18DV
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
nayther
Burbank, CA
I have one, use it when I'm plugged in for a period of time, keeps from overcharging the batteries since I have the piece of junk converter/charger. If you have the IOTA with the add on or float charger you should be able to leave the switch out (out is on).
edited 10/14/09 11:48pm by an administrator/moderator *
jetboater454
FL
If it's pulled out and you have 12V lights,then it's "on".Push it the other way and see if you have no lights.Then you can label it for on/off.
"If momma not happy ....Who cares.I have my TH AND my toys .
nayther
Burbank, CA
jetboater454 wrote: If it's pulled out and you have 12V lights,then it's "on".Push it the other way and see if you have no lights.Then you can label it for on/off.
I had to do exactly that, couldn't remember from one time to the other, made a little label that says, "out is on" for under the switch. Love the Brother label maker.
DIRT BIKES RULE
'05 Duramax CC short bed
'06 3005 Rage'n Falcon
BobWanderer
Perris,Calif,USA
nayther wrote: I have one, use it when I'm plugged in for a period of time, keeps from overcharging the batteries since I have the piece of junk converter/charger. If you have the IOTA with the add on or float charger you should be able to leave the switch out (out is on).
So I assume the fridge will work with the batts unhooked??
I have never tried it that way.
edited 10/14/09 11:47pm by an administrator/moderator *
CliffordG
Central Wyoming
BobWanderer wrote: So I assume the fridge will work with the batts unhooked?? I have never tried it that way.
I believe the Dometic fridge still needs 12v in order to run the circuit board (control panel).
2005 Silverado 2500HD with 8.1L and Allison 1000 pulling a 2007 WW 2800 FSW loaded with an 07 Suzuki Vinson, 07 Suzuki Eiger, 2007 Yamaha TTR50e, and 97 Suzuki LT80.
