RV.Net Open Roads Forum: Tech Issues: Lights on tow
 > Lights on tow
Tech Issues Related Tips
hottubkid
SCHAUMBURG,IL
Posted: 10/15/09 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2003 CRV and have wired a second set of lights in the rear but the lights will not light up brightly. You can almost see them at night. I bought a magnet set of tow lights and placed them on top and they light brightly. Any Ideas? I have changed the bulbsand the lightd do work as they should but do not light up brightly.
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
Center Pin
Fort Langley, BC
Good Sam RV Club
Posted: 10/15/09 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Sound like a ground issue to me. Time to pull out the multi-meter and start checking resistance.
Trailer: 07 Tango 299BHS
TV: 2004.5 Dodge 610 CTD 3500 QC 48RE 2wd Laramie SRW, FP Gauge, FASS 95/95, Rhino Lining, Hensley Arrow, Reese Signature Series 5er Hitch, Air Bags & Compressor, Canopy, AL Boat Rack.
Been running B100 home brew June 2008!
BB_TX
McKinney, Texas
Posted: 10/15/09 10:24am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Center Pin. Almost certain you have a bad ground.
Deen
Vancouver, WA
Posted: 10/15/09 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Or, because of the poor location of the new bulbs they just can't be seen? There have been more than one report here of poor lighting from the add'l bulbs not being in the correct location for the reflector to properly reflect the light. That's why I'm not a big fan of them and much prefer the diodes.
wolfe10
Posted: 10/15/09 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Does your coach have separate brake and turn lights?
If so, you have a 3 (left turn, right turn, brake) to 2 (left turn/brake and right turn/brake) ADAPTER.
Many of these adapters use poor quality diodes that have a lot of voltage loss across them.
So IF you have this adapter/wiring set-up, check voltage IN and OUT of the adapter and then at the lights at the back of the toad.
Let's face it, if you only have 11.5 VDC at the lights in back of the toad, they WON'T be bright.
There are some higher quality 3-2 adapters out there. If this is the issue, let us know.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
hottubkid
SCHAUMBURG,IL
Posted: 11/09/09 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Ended up being the plug that came with the blue ox lighting. Finaly replaced it and all's well
 > Lights on tow
