Can anyone tell me where the radio fuse is located on my 08 Seneca.
I've checked every fuse above the passenger's feet behind the panel. I have check every fuse under the hood. At wits end. It is not shown in the OEM manual that I have. I have Checked all the fuses and circuit breakers in the bed room.
My radio runs off the house batteries. There is an in line fuse just after the battery disconnect switch (of course this is not mentioned in any of the manuals).
bumpus4 wrote: Can anyone tell me where the radio fuse is located on my 08 Seneca.
5500 chassis/ 6.6 diesel/ Seneca HD 35Gs /'08
Thanks, bumpus4
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
The fuse on passenger side is #14. In case you missed it when checking.
Jayco uses a aftermarket radio. Like the Sony I installed it probably has a fuse in or behind radio. Pulling the IP bezel is not hard. Just start pulling out on passenger side of bezel about 1/2". Then move toward center, then steering wheel. You will need to disconnect cable that goes to the DIC. There are a couple of bolts holding radio in place that need removing. Slide radio out and find fuse. Good luck repairing the problem.
I found the fuse. It was in the house battery compartment hid among a bundle of wires behind and to the upper left of the batteries.
Thanks for the information, it sure made my day a lot easier.
regards, bumpus4
edited 11/01/09 07:18pm by bumpus4 *
