RV.Net Open Roads Forum: Travel Trailers: Faulty Tank Sensors ??
 > Faulty Tank Sensors ??
Travel Trailers Related Tips
sapoc
Burlington, Ontario, Canada
Posted: 11/01/09 09:25am Link  |  Print  |  Notify Moderator
I can never rely on my tank sensors to give an accurate reading and I was searching for a solution out there. I came across a replacement sensor call a Horst Miracle probe http://www.horstmiracleprobes.com/index.php that seems to be a logical and simple solution. I am simply wondering if anyone has replaced their sensors with these and do they work as advertised?
Thanks
Phil
Work interferes with our camping!
2008 Aerolite Cub 235
TV 2004 Aviator
Me=65 DW=Younger than me DS=94 DD=96 DD=93
tvman44
Southwest Louisiana
Posted: 11/01/09 09:36am Link  |  Print  |  Notify Moderator
They have to be better, but I would not expect even those to work perfectly all the time. If they do, I might change mine.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 11/01/09 10:46am Link  |  Print  |  Notify Moderator
I use this tank chemical and it seems to keep the tank and sensors clean.
Unique M and M -- RV Digest-It
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
robbie69
wauconda, il usa
Posted: 11/01/09 10:47am Link  |  Print  |  Notify Moderator
i bought the black tank ones then figured out it will be more of a mod than i planned. can't get to the original sensors(right up against the frame) so i need to extend the scensor leads and measure/drill new holes on opposite side of tank. that will end up being the 1st project of the spring.
after all this time of using the 'visual down the hole' method, don't know weather i'd really use it all that much-but the DW does--knew i should have never taught her how to use the monitor system
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
mowermech
Billings, MT
Posted: 11/01/09 10:58am Link  |  Print  |  Notify Moderator
I use the monitor system to check the battery and propane. Other than that, I ignore it.
Generally, when the fresh water runs out, it is time to get out of the woods, refill the fresh water, and dump the holding tanks.
Almost always, when hooked up to a continuous water supply, I am also hooked up to sewer, so no problem.
Over the years, through owning or using 6 different RVs, I never had sensors that worked. If I did get them to working, it only lasted one or two fill-ups at best.
I ignore them. I don't need the stress.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, 5 speed, 4.10 LS diff., Jacobs Rambrake, 274,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '08 Subaru Outback
Towed: '06 Jeep Rubicon Unlimited/Load Trail 16' flatbed
LAdams
Northern Illinois
Good Sam RV Club
Posted: 11/01/09 03:03pm Link  |  Print  |  Notify Moderator
Double Post - Post Locked...
Please do not double post across forums or in the same forum - it is against forum rules
Moderator - TT Forum
Link to postin Hybrid forum below
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23355049.cfm
