RV.Net Open Roads Forum: Towing: How Level should 5th wheel be towed
Search only in Towing
Open Roads Forum  >  Towing
 > How Level should 5th wheel be towed
Towing Related Tips
lpc511
Georgia
Posted: 11/03/09 12:34am Link  |  Quote  |  Print  |  Notify Moderator
Well, I had to drop the 16K Reese Slider down all the way and raise the pin box to the last hole as well to get level. Only then did it dawn on me why. I have the HEMI SPORT Package on my dodge and that come with 20 Inch Wheel. The 3 inch larger wheel had to be made up somewhere. Have not pulled it yet, but it sure looks better sitting in a straight line between trailer and truck.
Lou
Lou & Patti
2010 242FWRLSSR Keystone Sprindale 5th Wheel
2005 Dodge Quad Cab 5.7 ltr HEMI 1500
Retired Military
TomG2
Central Illinois
Posted: 11/03/09 04:18am Link  |  Quote  |  Print  |  Notify Moderator
Lou
That is exactly what I had to do and it was worth it. Let us know how it works for you.
randy&shereen
Jackson, MI
Posted: 11/03/09 04:43am Link  |  Quote  |  Print  |  Notify Moderator
Double check your clearance between truck box and the trailer overhang to make sure you still have 5-6" minimium. Also check that the bottom back of pin box is now not in a position where it will hit the inside walls of the truck box in a turn. Sounds like your on the right track but its the things that you don't double check that bite you. I ended up just slightly up in the nose to keep the bed clearance as I have a slight bank in front of the house. Some gas station driveways have short but steep transitions from the road to also be aware of. Randy
2004 GMC Sierra 2500HD SLT CREW CAB LONG BOX
8.1 Big block Gas/Allison 4:10 4x4
2004 Newmar Kountry Star 34 BLWB 3 Slides
lpc511
Georgia
Posted: 11/03/09 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Randy for the pointer. I have the 6" clearance from trailer overhang to bed, but I never thought about dipping way up or way down when pulling in somewhere. I need to try that on some steep turn ins for just how big of a dip up and down I can do without hitting the truck box with the overhang.
Lou
TomG2
Central Illinois
Posted: 11/10/09 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
lpc511
Have you done a test tow yet?
