RV.Net Open Roads Forum: Class C Motorhomes: Fixing up a 1979 Dodge Sportsman
 > Fixing up a 1979 Dodge Sportsman
Class C Motorhomes Related Tips
bgriffey
Wallins, KY
Posted: 11/07/09 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a photo showing the A/C unit lower then it should be
I also tore out the old cabinets today and of course found some more wood that need to be replaced. Tomorrow I will finish removing the sink and cabinet to see how bad the floor is.
Jarlaxle
New England
Posted: 11/07/09 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
It don't look like it's going to be hard to fix
It's not...a friend and I did pretty much the same thing with a 1977 Dodge Coachmen. It's all pretty basic. I'd rewire while it's apart!
A 4:1 bleach solution (4oz bleach in 16oz water) works wonders dealing with mold.
John
1984 Ford B-700 school bus conversion, Thomas body
A bunch of other vehicles
3 nutty cats (Maya, Vierna, Briza)
One lazy dog (Marmaduke)
One wife (Liz)
"A wasted youth is better by far than a wise and productive old age"
-Jim Steinman
bgriffey
Wallins, KY
Posted: 11/07/09 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Jaraxle,
bgriffey
Wallins, KY
Posted: 11/08/09 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well today I finished tearing out the sink & stove cabinet
I found a little rotted wood under the old cabinet and the plywood that covered the tire sheeting.
So far the floor looks good, but I'm going to remove the closet, the bath, the seats in the rear and the carpet. You never know where rot will be hiding.
RedRollingRoadblock
Oregon
Posted: 11/08/09 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
This looks like the start of another interesting rebuild thread.
John H
Kansas City Mo.
Posted: 11/08/09 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have to admire your, "Lets Get it Done Attitude" !!. Keep the photos of you progress coming, and Be carefull. No matter what stage you are at, ripping & tearing or assembly. Keep you mind ahead of the process. Wear a dust mask.
John H
Jarlaxle
New England
Posted: 11/08/09 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
And don't drop roof vent fans on your head. They're heavier than you think.
I will let you figure out for yourself where this knowledge comes from. And yep, you're probably right.
tiogaarrow
California
Posted: 11/08/09 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
I srongly suggest cutting out that gray polybutylene water piping (leak prone,50% falure rate), and replacing it with pex tubing, while you have it accessible.
overdrive75
Whitmore Lake, MI
Posted: 11/09/09 04:00am Link  |  Quote  |  Print  |  Notify Moderator
In that shot where you can see the filler neck, replace the rubber vent line while you can get to it easily. On our previous Dodge that was leaking and you can only imagine where that raw gasoline would go when fueling.
1987 Shasta Roadmaster 27' E-350 with gas hog 460
Southernsuzy
Alabama
Posted: 11/09/09 04:10am Link  |  Quote  |  Print  |  Notify Moderator
Take pictures of the framework from various angles BEFORE you take it apart. Will come in handy later on.
