Grizzly Man
Candler
I need someone to provide a photo of how the power converter should be installed in a Fleetwood TC. As you can see from the photo the power converter in my TC is not installed correctly. The converter works great but should not be sitting in the floor. It appears a cabinet door is missing where the converter is sitting. Any help is greatly appreciated.
2006 Fleetwood Scorpion S1 Toy Hauler (for sale)
1992 Fleetwood Caribou 8CS TC
5Alive
Salt Lake City
I believe on the old magneteks the converter and fuse panel were basically one unit. Mine is and since I've been researching a replacement I've seen pictures of others. My guess is that your camper didn't come with a converter and someone just added it.
1995 Weekender 1010 Ext
2005 Dodge Ram 3500 DRW 4X4 CTD Regular cab
5Alive
Salt Lake City
Here's mine. The converter portion is behind and below the fuse/circuit breaker part.
I should have my new upgrade converter by this weekend. If I remember I'll take a picture before ripping the old stuff out.
JoeChiOhki
Keizer, Oregon
That looks like one big sloppy ass mess..... Please tell me you pulled that converter box out? Who on God's green earth, puts a converter below a water tank, then makes a giant open grate in the side of the water tank step to vent it? That has got to be the cake taker for stupid designs....
Follow along with me at The Journey of the Redneck Express
CB Channel 17 Redneck Express
'1992 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
Grizzly Man
Candler
JoeChiOhki wrote: That looks like one big sloppy ass mess..... Please tell me you pulled that converter box out? Who on God's green earth, puts a converter below a water tank, then makes a giant open grate in the side of the water tank step to vent it? That has got to be the cake taker for stupid designs....
I just purchased this TC and need to figure out how the converter should be installed. This is how it was when I purchased the TC last week. I would like to put it back to factory specs.
Grizzly Man
Candler
I'm not talking about the OE power converter with the fuses. I'm concerned about the power box in the left side of my photo. The box with the red wires.
BrandonR
Oregon
Looks like a retrofit to me. You should have a door there for accessing the area in front of the wheel well so you're missing the door and have that hulking monstrosity in it's place.
Brandon Reed
Albany, OR
Grizzly Man
Candler
BrandonR wrote: Looks like a retrofit to me. You should have a door there for accessing the area in front of the wheel well so you're missing the door and have that hulking monstrosity in it's place.
I think you are correct. After looking into this, the "retorfit" unit is wired into the factory power converter. I'm not sure why someone wired in the retro unit because all of the brakers and fuses work on the factory unit. I will build a vented box for the "retrofit" and relocate it out of sight.
Murgatroid
Nevada City, CA
The Fleetwood Elkhorn 9T I had had the converter in the same spot. My converter died one day. I can see that a previous owner just wired in a new converter to replace the broken one and didn't bother with the fuse/breaker panel. Since the old Magnateks' are a simple design, I found that mine had a blown power resistor, so I replaced it and it worked just fine after that.
I would look into replacing the converter with a more modern 3-stage one.
And, yes, Fleetwood really did design the camper with the electrics at the bottom of the fresh water tank. It probably would not meet with UL approval...
-steve
2009 Northern Lite 9.6Q Classic
2009 Outfitter Apex 9.5 (soon to be for sale)
2009 Sundance 2800RLS
2006 Dodge Ram 2500 QC LB CTD 2WD
WTTCS
freedom , U.S.A.
On my Caribou, it is under the sink , attached to the front wall, behind the sink cabinet door, AND OUT OF SIGHT.
1997 chev crew cab 454, 5 sp. 4.10
2000 Fleetwood Caribou 11.5
2006 3500RL Montana
