RV.Net Open Roads Forum: Every hose I get leaks at the connections!!!
 > Every hose I get leaks at the connections!!!
Travel Trailers Related Tips
robbie69
wauconda, il usa
Posted: 11/04/09 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Bigburd wrote:
webslave wrote:
As has been mentioned... Pick up a 90 degree elbow at an RV store. If the hose hangs straight down from the side of the TT it takes all the stress off of the connectors. Have always used one and never had a leak...
That and a good set of pliers.
these 2 and a good washer-preferable the softer rubber, not the hard plastic ones. the better it compresses/forms to the hose end, the better the seal.
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
harper223
West Texas
Posted: 11/04/09 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I thought all washers were the same. I guessed wrong. Will upgrade those for sure.
Steamguy
Camas, WA, USA
Posted: 11/04/09 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
I put on a quick-connect a while back with an O-ring. Seems to work well, since it's heavy brass and hard to deform. The hose ends on the white hoses seem to deform easily. The quick-connect at the faucet to hook up the pressure regulator sure makes life easier. I don't have to fiddle around with the regulator to get things unscrewed.
Just a thought.
roverdover
Russellville, Alabama
Good Sam RV Club
Posted: 11/04/09 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
The crimped fittings on the male end is where mine ususally leaks. Where mine fastens to the camper is already at an angle. I just assume it is the Wal-Mart hoses I buy. (No flaming of Wal-Mart intended.)
redwake
Visalia, CA
Good Sam RV Club
Posted: 11/04/09 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
i use a 45 rather than a 90 elbow for my city connection.. some pliars to attach firmly never had a leaking problem.
i also put my regulator on the hose bib to reduce weight on the city connection (there is a theory that pressure can build up in the hose and you are suppose to put the regulator at the city connection point).
TT: 08 Monterey 27 PT by Extreme RV
TV: 06 Sierra K1500 SLE Crew - 3.73:1 4x4 w/5.3L
Hitched with a Husky WD & SC.
Powered by Champion 3500
tafische
Memphis
Posted: 11/04/09 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have found that white tape (I think it's called "plumbers tape") works very well in stopping leaks at the connections.
Good idea in a pinch. It is called Teflon Tape. Need to thrown some in my toolkit.
harper223
West Texas
Posted: 11/04/09 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty cheap too. But mine always seems to leak either from the crimped part of the hose, or the connection itself (the washer connection). Great suggestions
webslave
Clearville, PA
Good Sam RV Club
Posted: 11/04/09 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Steamguy wrote:
I put on a quick-connect a while back with an O-ring...
I have quick-connects on all of my hose fittings. "Y" connector on hose bib to pressure regulator (stays connected to hose), hose to filter, filter to city water inlet. Also use them on my gray hose for connecting to my Tornado washers. I've found the brass ones to hold up extremely well, don't leak and you don't have to worry about pliers to attach or detach them from equipment.
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2008 FunFinder X 210WBS
2008 Jeep Hemi Commander Limited
Eqaul-i-zer 10K
Prodigy P3
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 11/04/09 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Look at then ends of your hose on the inside of the coonectors. You will see that most now are very sharp. This doesn't allow for good mating surfaces. I bought some bress hose to hose fittings for each end. They have much better surfaces for the conections.
Bud
Suzuki XL7 pushing Pace Arrow
tvman44
Southwest Louisiana
Posted: 11/04/09 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
I bought several of the quick connects with the "O" ring and love them. I have about 7 or 8 sets and use them on all water connections from the faucet to the 5er including the water filter. Also use them on the Quickie Flush and Flush King.
Just a thought.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
